Quoted from gweempose:This is excellent news! Did Gomez happen to mention if there is any reason for someone to install the fixed code if their game is currently working fine?
Would like to know this as well, since my is running fine so far...
V1.25 - May 29, 2015
- Fixed machine reset issue that occurred on some machines at system
start up, during attract mode, and/or during gameplay.
No need to install 1.25 if 1.24 installed fine on your PRO\LE etc:
Release notes on 1.25
If it was me, i would probably just update to 1.25 just in case problems pop up in the future....
BUt on the other hand... dont fix what isnt broken
Yep, from their FB page:
Thank you for your patience! We've found and fixed the bug that was introduced with TWD v1.24. The bug was a memory management issue that manifested itself during certain unique conditions. Everyone that has successfully installed v1.24 for any model(Pro, Premium and LE) should also update to v1.25 since the potential issue exists in all versions of v1.24.
After 260 plays, having an issue on this LE.
In attract mode, it seems to get to the barn champion and reset every single time. I will play a game and it will not reset on its own.
Has anyone seen this specifically? Or, am I afraid I'm the only one?
*edit: I will try updating the software tomorrow to see if this works.*
Quoted from PinLen83:I've eliminated the possibility of a bad outlet by moving it to another one: same results.
Have you moved on to 1.28? Sounds like the 1.24 issue.
Quoted from ezeltmann:Have you moved on to 1.28? Sounds like the 1.24 issue.
It fixed it right away. Couldn't believe that after so many plays it randomly just decided it wanted to reset during attract.
I'm so happy it's fixed! Plus, I've updated to Millhouses sound update. Loving it even more!
This page was printed from https://pinside.com/pinball/forum/topic/twd-124-games-resetting/page/3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
