Just got a tumbler and am using walnut as the media.
I was sent 2 different walnuts...a fine and medium grit.
The fine is like sand and the medium is 1mm-2mm grains.
What coarseness is the stuff you are using?
At the moment I'm using a 50/50 mix and the results are not so impressive.
Ive put in some Novus 3 as well. How much should I put in? Anything else I should add?
