(Topic ID: 245868)
[TSS] player 1 display outputs garbage future queen
By Simonvb
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by Simonvb
#1 4 years ago
When i got the game the fuse was burnt. I replaced it and all the displays had issues. I reflowed all the heather pinns on the mpu but player 1 still has issues. Wen i score it does not change. I have swapped the player 1 display with player 4 but nothing changed. P1 still has issues. The pin is future queen. It has an :
as-2962-91154-e mpu from bally.
What can i do to fix this ?
#2 4 years ago
Maybe cabling? Maybe corrosion?
#3 4 years ago
All connectors are clean. i just took a break after destroying the playfield glass of my dnd... il go back to ckeck on the wiring.
#4 4 years ago
It looks like the cables are still fine i think the problem might be on the mpu. Since swapping displays did not help. Il go check for cold solder joints again
#5 4 years ago
The signals from the MPU board to each display is daisy chained. It means all the signals to the displays are the same except for a single wire that selects the display. At the display boards this is pin 15 at the connector.
Pin 15 of Display 1 is likely a black-white wire which comes from the MPU board at J1 pin 20.
You likely have a bad connection at either end of this wire preventing display 1 from being selected at the correct time.
#6 4 years ago
Thanks il try after work today.
This page was printed from https://pinside.com/pinball/forum/topic/tss-player-1-display-outputs-garbage-future-queen and we tried optimising it for printing. Some page elements may have been deliberately hidden.
