My simpson's pinball party has a weak upper playfield right flipper making the couch shot hard . Are there any easy fixes ? I have the Pascal board mod that shuts off upper flippers when ball not there. Any help ? please and thank you
An easy fix - loosen the spring.
I had amazing success with a similar problem on the insanity falls shot with the upper flipper on Wh2o.
The most minor change in tension made a huge difference in flipper strength.
Not sure if it also applies to the upper playfield flipper that loads the couch, but I know that the long shaft of the upper playfield flipper that loads the TV sometimes binds on the edge of the upper playfield.
Loosen off slightly the black knurled knobs that hold the upper playfield in place and see if that makes any difference to the strength of the couch flipper.
Quoted from RTS:An easy fix - loosen the spring.
how do you loosen the spring ?
Do you have the flipper strength set to high? Try that and see if the ball makes it up easier. It worked for me.
Quoted from luch:In the service menu which function do I change ? is it coil strength ?
Yes. That is the one.
Quoted from luch:how do you loosen the spring ?
Just manually stretch it so it's not as tight, but still retains some tension. But be careful not to overstretch it removing all tension. If that happens, the spring won't work at all. Best to just stretch it a little bit at a time to measure the improvement.
The spring does not need to be wound really tight to snap back effectively. An overly tight spring can weaken the strength of the flipper. A slightly looser spring will still snap back fast enough, as long as the spring still has enough tension to return the flipper to the resting position.
Quoted from RTS:Just manually stretch it so it's not as tight, but still retains some tension. But be careful not to overstretch it removing all tension. If that happens, the spring won't work at all. Best to just stretch it a little bit at a time to measure the improvement.
thanks
This page was printed from https://pinside.com/pinball/forum/topic/tspp-upper-right-flipper-weak-any-easy-fixes and we tried optimising it for printing. Some page elements may have been deliberately hidden.
