I dug out my manual, and unfortunately all Stern included was a picture of the TV board....No schematics and I can't find where the other end connects to. I would guess it makes it's way back to the MPU. So, try to trace that connector back and reseat the other end.
I found this for you....Lifted from a post by Clay on RGP:
I have a Stern Simpsons Pinball Party. I had the
game 'down' for a couple months, and put it
back up today. And the LED "Tv" was not working.
Strange, it was working when i folded the game
two months ago.
So here's what i went through to fix it. I figured
this may help someone in the future.
1. Check for +5 volts at the LED TV board
(on the playfield). There is but one connector
going to the TV. And the Red and Black wires
are +5 and Gnd respectively. Check for +5 vdc.
If you don't have power, the TV will never work.
In my case, there was 5.06 vdc at the TV board.
2. Check the input signals. The remainder of
the Orange wires at the TV connector are the
input signals from the I/O driver board. Note
Stern DOES NOT have a schematic for the
TV board in the manual! Wow, why not Joe
Blackwell? And where might i find this schematic
Joe? (Maybe it's on their web page?) If someone
has this schematic, please email it to me and
I will host the file.
Anyway, since the TV board is all surface
mount, i will assume it's Ok (because I don't
really have any way to fix it!) There are lots
of 74LS574 chips on that board, and a HTC04.
But anyway, check the input signals using a
logic probe. All the Orange/xxx wires need to
have a signal of some sort. Basically they
should all be pulsing (maybe one or two was
low, can't remember).
In my case, the Orange/Gray wire has NO signal.
Ha! Well that will do it. If you are missing a signal,
the TV won't work. So why was there no signal?
Now go up to the I/O Power Driver board in the
backbox (the big lower board). Connector J2
(upper right corner) has all the orange wires
going to the TV. Here's the layout:
J2 pin 1 - org/brn
J2 pin 2 - org/red
J2 pin 3 - org/blk
J2 pin 4 - KEY
J2 pin 5 - org/yellow
J2 pin 6 - org/grn
J2 pin 7 - org/blue
J2 pin 8 - org/purple
J2 pin 9 - org/GRAY
J2 pin 10 - org/white
These all go through a 100 ohm resistor.
Check ALL of these resistors with game
off using a DMM. If one is open, that will
stop the signal coming from chip U201.
In my case, these resistors were all good.
Checked J2 pin 9, my Orn/Gray wire,
there was NO signal. Looking at page 123
of the manual shows this leads to chip U201
(HCT273) on the I/O board, pin 19. Input
to this pin is U201 pin 18. So there should be
a signal at U201 pins 18 and pin 19.
No signal at U201 pin 18 means something
upstream is bad (U200), no signal at U201 pin 19
means U201 is bad.
In my case, I could SEE the problem
I should note, that this game has BATTERY
CORROSION. i installed a remote battery
pack on the CPU/Sound board, and cleaned
up the corrosion. BUT BUT BUT there was
corrosion at the U201 chip! Now how did that
happen? There's no batteries on the I/O board.
But somehow...
Well anyway, a wire brush to this area (game off!)
and a quick touchup of the U201 pin 19 solder
joint, and the signal was now at J2 pin 9.
And the TV LED worked!
Hope this info helps someone.
