(Topic ID: 215017)
TSPP Problem
By grahamharley
2 years ago
  • 15 posts
  • 7 Pinsiders participating
  • Latest reply 2 years ago by D-Gottlieb
#1 2 years ago
I have a Simpsons pinball party that was working fine, turned it on the other day and the DMD is flashing and the game appears locked up, A few gi lamps are lit but other than that seems frozen
any advice is greatly appreciated
John
#2 2 years ago
Sorry you're having trouble. Always start by re-seating all connectors. (unplug them and plug back in)
#3 2 years ago
did you look at the cpu board where the batteries are at.any signs of corrision on or near the ic roms
#4 2 years ago
the owner had left the batteries in and they were corroded but nothing seemed to effect the boards, the game worked fine for 3 weeks after I replaced the batteries
#5 2 years ago
Quoted from grahamharley:
they were corroded
thats probably exactly your problem with the game.the corrision leaks behind the battery holder also
#7 2 years ago
There is nothing on the board from the batteries I reseated all of the cables and ribbons
The dmd still flashes and game is frozen. I tried going into diagnostics and nothing
#8 2 years ago
Check your game and display roms, pull them and reinsert them
#9 2 years ago
Pulled an reseated both rooms no change
#10 2 years ago
call chaz at stern
#11 2 years ago
Bump
hoping to get some more insight on this
Simpsons pinball party was working fine, now when game is turned on DMD flashes and some GI's light other than that the game is frozen
#12 2 years ago
You said the old batteries were corroded...did you do anything besides replace them? For example: clean the contacts inside the battery holder to remove the corrosion?
Mine was experiencing similar symptoms recently. Replacing the batteries and cleaning off the corrosion from the batter holder springs/contacts did the trick.
#13 2 years ago
I did not clean up the contacts, Will do tomorrow
#14 2 years ago
I cleaned the battery contacts today and it seemed to have fixed the issue,
thanks for the great advice.
#15 2 years ago
Batteries have no business on the board. I hope you get this fixed. Afterwards, get a memory chip and no more batteries.
4,900 (OBO)
Kingston, NY
