I bought a tspp from somebody at pinside. So far, so good. But being that this is my first pin and unfamiliar with it, I need to know how to keep the high scores from resetting. What happens is if I turn the machine off for 24-48 hours, it comes back on and says, "open the door". So I do, and everything works fine, except all the high scores are reset.
I figured it is probably batteries somewhere that need to be replaced. I did find a bank of 3 batteries in the head when I took the back glass off. Will changing those batteries fix the problem? The issue I have is that they seemed to be held in place with one of those plastic ties and looks very secure. And I don't want to cut that if that is going to break something.
Or is the problem elsewhere? Any help would be appreciated. Thanks.
