1. Installed new lcd Color DMD following instructions
2. As an initial test, routed Color DMD power cable outside of machine to the 5v/12v aux jack in the front-right of the machine
3. Booted up machine, Color DMD seemed to work (I saw high scores, etc)
3. Updated Color DMD to TSPP 4.1 ROM.
4. Went back to route Color DMD power cable properly through the cabinet. Also wiped down the playfield. Replugged it in to 5v/12v aux jack
After 4., it's not working properly and I'm getting various strange behaviors when booting up the machine. What I see most often:
1. turn on machine
2. "Stern Pinball Simpsons Pinball Party Display Version A5.00" appears on the DMD. At same time, TV on PF displays "TEST"
3. After a few seconds, the DMD goes blank, and the TV on PF is still saying "TEST" (for longer than usual)
4. After a few more seconds, DMD still blank, TV on PF goes into normal operation (it's scrolling "stern pinball" in below shot)
Another thing that has happened once
1. Turn on machine
2. Color DMD is blank and TV on PF is all solid LEDs (I forget if Color DMD initially displayed "Stern Pinball Simpsons Pinball Party Display Version A5.00" prior to this)
I don't believe issue is with Color DMD itself. It displays. It's LED lights up as "DONE". I can go into the menu...
I've double/triple/quadruple checked pins on data cables are facing right way... here's what it looks like
Other things I've tried:
- reseating ROM on Display Controller Board (the original Stern one that's mounted to the Color DMD assembly)
- Reseating all ribbon cables in the backbox
- Reseating many of the power cables in the back box
- Checking/reseating connections to various cables in the cabinet where I routed the Color DMD power cable
- Tried a different 24-pin ribbon cable from CPU/Sound board to Display Controller Board
- Followed trouble shooting at Color DMD website (the only measure I didn't understand was "turn the game OFF and try reseating the blue 40-pin LVDS cable at both ends by lifting the pullbar and sliding the connector gently out of the socket." I don't find any 40-pin cables anywhere.)
I suspect something unrelated to Color DMD got messed up during the install, but I really don't know. It seems like the Display Controller Board is talking to the Color DMD given the initial ""Stern Pinball Simpsons Pinball Party Display Version A5.00" is displayed, but somehow data is not coming through right from the CPU/Sound board to Display Controller Board (I did try a different cable). I have not yet tried reinstalling the original DMD and seeing what happens, but I may do that.
Thanks for any assistance!
