So I am having an issue with TSPP couch multi-ball, now that I understand the rules, here is the problem:
As I lock balls one and two into the couch, it appears to work fine (shows I have a ball locked, brings up another ball to shoot). But when I hit the third ball in, nothing happens, then the "ball search" feature starts, and one ball gets released from the couch, and then couch multi-ball starts.
First thing I did was enter the switch test mode and watched as each ball went into the couch, all three switches appeared to work correctly. (rolled over the switches in front and then each switch remained ON as the ball was over it).
Perhaps I just need to do this test several more times to see if sometimes maybe the switch doesn’t stay engaged?
Any thoughts on where to go next?
