All of a sudden my CBG standup stopped working when playing but works fine in test mode. I thought maybe something else on the same row or column but everything else also seems to work fine also. I'm scratching my head a little here, any ideas?
How are you testing it in switch test mode? If you are taking your finger and pushing the switch in, it has a nice long time to activate. Could be a ball flying at a decent clip isn't activating it even if your finger is.
I would take a business card, put it between the contacts of the switch, hold the switch closed, and then pull the business card out 2 or 3 times.
Sounds like a dirty switch.
I'm testing with my finger in test mode and in game ( glass off ) so tapping it the same in both cases. It registers every tap in test, but does nothing in game. Really confused.
Clean it. Takes 30 seconds, it's the very first thing I would try.
Quoted from Kevlar:I'm testing with my finger in test mode and in game ( glass off ) so tapping it the same in both cases. It registers every tap in test, but does nothing in game. Really confused.
This was making no sense to me at all, the switch is obviously working and it's position being seen as it worked perfectly in test so I just reset the machine to factory and now it's working again....go figure. I did change the CPU and display roms from v4 to v5 yesterday but had played a few games with no problems since then. I guess I'll have to see if it happens again, although I don't know what a permanent fix might be, maybe the roms I fitted aren't quite right?
Thanks for the help.
I saw this at lunch time and didn't have time to post. A similar thing happened on my TSPP. My CBG target would test fine in tests, but during play it would register as the monorail switch, and the monorail would start hurry-ups! Factory reset fixed it and it hasn't returned. You're probably good to go.
Quoted from Dewey68:I saw this at lunch time and didn't have time to post. A similar thing happened on my TSPP. My CBG target would test fine in tests, but during play it would register as the monorail switch, and the monorail would start hurry-ups! Factory reset fixed it and it hasn't returned. You're probably good to go.
Thanks Dewey, sounds like the simpsons software still has some unresolved bugs in it then.
This page was printed from https://pinside.com/pinball/forum/topic/tspp-cbg-standup-target-not-working-in-game and we tried optimising it for printing. Some page elements may have been deliberately hidden.
