New! Dark mode!
(Topic ID: 272629)
Trying to ID a relay board from Bally machine - ON BEAM?
By too-many-pins
3 months ago
  • 4 posts
  • 4 Pinsiders participating
  • Latest reply 3 months ago by DCP
    #1 3 months ago
    I bought a trailer load of parts over the weekend and I am trying to ID some of the stuff. One item I am trying to figure out is a relay board from a Bally machine. It has the metal bracket for the "service position" like is used in an ON BEAM. I have never seen that set up before what other machines used that style relay board with the entire relay board able to pull out like On Beam?
    Also this relay board has an "add a ball" stepper and the unique leaf switch stacks on reset bank & score motor that look similar to a Chicago Coin machine. Could it be anything else other than On Beam? That stuff doesn't look like it was used on many Bally machines?
    THANKS!
    #2 3 months ago
    2 of the Bally games I have in my possession have the "lift-out mounting board" I think they did away with it when they introduced the newer style coin door
    https://www.ipdb.org/files/201/Bally_1966_Bazaar_New_Lift_Out_Mounting_Board_Instructions.pdf
    I am not familiar with the add-a-ball relay or any documentation on how to make it work.
    #3 3 months ago
    1967 Rocket III also has the lift out motor board. As a side note, it's really cool as you can run the machine with the relay board raised, playfield and canopy glass both hinged up.
    On Beam is listed as Add-A-Ball convertible which on several games of that era is a plug in relay (Rocket III, Surfers, MiniZag etc) but the On Beam schematic clearly shows a 5 position Add-A-Ball stepper unit.
    #4 3 months ago
    Minizag has a lift-up relay board, too. Very handy design!
    $ 12.95
    $ 40.00
    Arcade Arts
    $ 90.00
    Lighting - Under Cabinet
    $ 119.95
    Hookedonpinball.com
    $ 19.95
    $ 7,500.00
    $ 29.50
    Playfield - Plastics
    $ 55.00
    Pinball Photos
    $ 32.00
    The MOD Couple
    $ 68.50
    $ 32.00
    $ 1,199.00
    $ 48.00
    $ 29.95
    Apparel - Unisex
    The GameRoom Store
    $ 18.99
    $ 9,999.99
    Little Shop Of Games
    $ 5.00
    $ 229.00
    Tilttopper
    $ 999.00
    $ 47.00
    Cento Creations
    $ 799.00
    $ 221.00
    Cabinet Parts
    Tilted Pinball
