Hi guys, finally getting around to getting the right sling going on my special force pb and found a problem reading the wiring from the coil to the board. I was hoping that one of you special force owners would help me. I grounded the transistor tab and got the coil to fire but I can't seem to find where the wire from the coil to the plug goes to. The wiring diagram shows two places and neither one has a wire to it. Can someone direct me to the proper plug and pin number? I was thinking I would just run another wire from the coils lug to the correct pin and see if it works. The location says it's cj7-1 and the diagram shows it going to CJ 6-4. Sorry for the terrible pics but the scan sucks. Hope it makes sense.
