(Topic ID: 296248)
Trying to diagnose bad playfield hole kicker (Zaccaria Space Mission)
By swampwiz
3 months ago
  • 4 posts
  • 1 Pinsider participating
  • Latest reply 22 days ago by swampwiz
    #1 3 months ago
    There is a hole at the top of the playfield which works properly sometimes, but other times actuates too weakly to pop the ball out, and sometimes nothing at all. The coil is a D.40 S.1200, which is cross-referenced with the Williams 26-1200, which I have bought to replace it with (the replacement coil officially says "AO-26 1200").
    So I've take the coil out of the housing and measured its R, L & diode:
    10.5 Ω
    10.6 mH
    0.011 each way
    The replacement shows basically the same readings.
    I'm not sure how to interpret the diode reading, other than to presume that there is a "short" through the coil itself, so a proper read on the diode is impossible.
    I'd like to think of everything I should try before swapping out the coil. I suppose I could try checking the elements on the driver board, but after that I have no idea.
    #2 3 months ago
    OK: I checked some elements for this coil, and I get (with the connector out) the same readings as for the set next to it that uses the same connector.
    RESIST: 360 Ω, 150 Ω
    CAP: 19.5 pF
    DIODE: .54, .704
    TRANS:
    R1,B2: 0
    R1,B3: 0
    R2,B1: .555
    R2,B3: .303
    R3,B1: .503
    R3,B2: .299
    #3 3 months ago
    BUMP
    2 months later
    #4 22 days ago
    BUMP 2
