New! Dark mode!
(Topic ID: 207352)
(Solved) Troubleshooting no GI lights
By PinballTilt
2 years ago
  • 16 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by tonyhoff1
There have been 6 images uploaded to this topic. (View topic image gallery).
#1 2 years ago
Looking for some help with an issue I'm having on a Data East Jurassic Park. I thought I had gotten to the bottom of this, but now I'm not so sure.
A little background: Picked this game up from a fellow pinsider who was very upfront that it had an issue with the GI system. There are no GI lights at all. It appears the game and lights were working fine, but there was a fire and when I bought the game alot of the wires had been burnt and disconnected while the issue was investigated. I'm guessing now, but I think this game was functioning with a Rottendog MPU board and original power supply board. Then the fire happened and an Xpin power supply was added to the game along with a Inkochnito rectifier board. The issue wasn't solved and ended up smoking some traces on the new Xpin board.
So I bought the game and set about trying to fix the issue. I replaced all the burnt wires and GI connectors, header pins, and molex pins. I talked with the Xpin guys and ordered a new relay and diode to fix their board. Replaced that and repaired the trace. I also found a shorted Q28 transistor on the MPU. Q28 is the transistor that drives the relay coil. I figured this transistor was the original failure and it smoked the wires and traces and started the fire. I replaced the transistor along with the U1 and U5_f chips in case those were affected by the short.
That brings us to today and the reason I'm asking for help. After doing all that I turned it on and the Q28 transistor I had replaced shattered. Now I'm sure it's possible I just got a bad transistor, but most likely there is still an issue. I was thinking that if the transistor failed again, there must be a short. I checked for continuity to ground on each of the GI relay pins and don't have it. There is also no continuity between the two pins for the GI relay (checked that in case the repair I made on the trace was shorted). It also doesn't appear the transistor is shorted like it was before, if I check continuity from the metal tab to ground, I don't have continuity.
Given all of this information, can someone suggest something for me to check or try? I'm not sure where to go from here as I thought I had fixed this issue. Here are a few links for the schematics. Please help me figure this out
http://www.rottendog.us/MPU004.pdf - Rottendog MPU
http://mirror2.ipdb.org/files/2493/Tales_From_the_Crypt_Schematics.pdf - hi def schematics
#2 2 years ago
It could be someone has hacked the 6 vac GI circuit and messed it up. Disconnect CN 7 on the PS. That will disable the transistor circuit that is blowing apart. The GI is designed to be on constantly and the relay circuit turns it off. Check for proper voltage and continuity at the GI pigtail connector. There are four wires. 2 wires for each side of the AC voltage. 2 of them pass voltage onto the PPB from CN 8 on the PS to the PPB and is fused there. The other 2 run through the relay that is energized from the transistor you replaced. When the relay is at rest the GI is on, when the relay is energized the GI is off. Good luck.
#3 2 years ago
Also CN 8 may be wired wrong.
#4 2 years ago
With the GI. Unplug cn12. If the GI comes on then it’s in the board. I also had that problem on a ver3 board. Never could figure it out. So I pulled the transistor and put it on route for an operator as he did not want to send the board out or get a new one. It’s been on route for about a year. Never heard anything else about it so it must still be working
#5 2 years ago
Quoted from mikat11:
Thanks. It blew apart with that disconnected. I had left it disconnected from the power supply just to measure the voltage coming from the transformer
#6 2 years ago
They will just always be on.
#7 2 years ago
Quoted from tonyhoff1:
If I'm not mistaken, unplugging cn12 or at least the pin would just serve to disable the relay, correct? So the lights could then not be shut off. I could try that, I would just have to pull this transistor since it's compromised so no fire starts again.
#8 2 years ago
Here is cn8
#9 2 years ago
Yes pull Q28
#10 2 years ago
Heee is GI on Power Supply
#11 2 years ago
Check this connector also as this one was burnt and was shorted
#12 2 years ago
Thanks for your pictures. I did notice last night that my red and brown wires were switched on the power supply. These are the wires just below the gi connector and run to the relay. I figured it didn't matter since it's just enabling a relay. Should I switch them back to how yours and the schematics show?
#13 2 years ago
Is that the z connector for the topper or for the backbox? I repined and replaced connectors for both, but I can double check my work
#14 2 years ago
That’s for the backbox
#15 2 years ago
Thanks for the help! I didn't realize I could just get rid of the transistor. So I removed that and I double checked my wiring and it was all good. Fired it up after reconnecting power from the transformer and the gi works. Thanks!
#16 2 years ago
Glad I could help some lol
$ 29.95
$ 99.00
Arcade Upkeep
Gweem's Mods
