I'm taking on my first "project" pin, a Data East Secret Service, and was hoping to get some advice on the general process to troubleshoot this game (and pins more broadly).
The prior owner noted that he plugged it in and powered it up once briefly and noted that it made a humming sound (seems to be standard for DE games, working or otherwise, to make this noise?), but that the playfield didn't light up and the game didn't start. I was advised to check everything over carefully before turning it on, lest I find myself with smoke and fire.
So I've looked through the DE-specific info on the pinwiki, and checked out the following guide for things to test: techniek.flipperwinkel.nl/desega/index1.htm (not linked since I just created this account and can't add links)
The fuses test fine (and clips are solid), the transistors seem good, no obvious burns on the molex (but I need to admittedly take a closer look), and I'm slowly working through the other recommended things to check before powering it on again.
So my question is, what else should I review before I try turning this on again for the first time? It seems like troubleshooting this is really going to require powering it up to better diagnose, but I want to make sure I've covered my bases before flipping the switch. What sort of things could I test (sans power) that might cause damage if they're in a broken state?
And once powered up, is there a general plan of attack for troubleshooting? Is it kosher to disconnect everything from the power supply and then test voltages coming off the connections, then slowly re-add connections to the CPU, GI, etc? Any particularly good order to do this in? (I read up a bit on bench testing the CPU board with a PC power supply, so I was going to test that separately to see if it's working as expected.)
Most of the guides I've found seem to be geared towards troubleshooting a game you knew was previously working, but I'm starting from scratch on a dead game. I want to make sure I take the proper precautions as I troubleshoot.
Thanks in advance for any shared insight/wisdom. I'm new to pins (other than an EM I grew up with at my parents' home), but I'm an arcade collector looking to expand my skill set into a new domain.
