(Topic ID: 290544)
Troubleshooting a Scorpion - Williams Sys 6
By northerndude
#1 3 years ago
Hey folks and pin-tech geniuses.
I'll post my early issue here and add pics with my phone after.
Story - I picked up a non-working Scorpion last week, previous owner said blowing solenoid fuse - SB 3.5A. (there was a 4 SB in there)
I figured, ok, lets chase that trouble down as see where it goes. When I was at his place, I flipped the power on, the GI came on and pretty much that was it. I turned it off and took it apart.
I came home, took PF out, started on that cleaning and shop out. BUT today I tossed the head back on, clipped the wire harnesses together- sans playfield and flipped the power on.
The displays, GI in head and looked like it fired up. I went through a few tests, illumination and displays tests to make sure it was good to go.
After a bit, I noticed that dusty "heat odor" and i flipped the power off. I could tell these big resistors were quite hot! Hot like the solder was soft where the leads hit the board. So, that's where I sit now.
Don't quite know where to continue here as I don't see what I should chase first. Having no playfield in? Did it need that? could that be why its hot as balls. I checked the rest of the fuses to make sure they weren't incorrect amperage
BEA399E0-5FA0-40FF-8ECF-F31E5662886E (resized).jpegBEA399E0-5FA0-40FF-8ECF-F31E5662886E (resized).jpegD8EB218A-E1AB-408E-B940-A3808E7D6987 (resized).jpegD8EB218A-E1AB-408E-B940-A3808E7D6987 (resized).jpeg
#2 3 years ago
Those resistors just simply run hot. Look either in the vid1900 thread or pinwiki on options to replace - you can replace transistors with mosfets and jumpers, or increase the size from 2 or 3 watt to 5 watt on those.
#3 3 years ago
Quoted from slochar:
"melt the solder" hot? wow
I don't mind trying to find out what to do. I can do a bit of soldering
#4 3 years ago
HOLY SHIT - found it exactly, low, low down the page on pinwiki, THX
this pin had "some" bulletproofing done by Devron in Saskatoon, too bad he didn't get to this.
So, the pin was on, with only the head on, and no playfield plugged in, and this is how hot these got. FYI. unreal.
#5 3 years ago
Any other items I should be thinking about with these boards while i'm ordering transitors?
Already has off site battery holder and some upgraded rectifiers I think also
#6 3 years ago
How’s the 40 pin connector? How about the rest of them. May also want to think about protecting the machine from failing bridges - if I remember right, they are not fused.
#7 3 years ago
When the CPU locks up the blanking circuit is supposed to trip and turn off the solenoids and lamps. This circuit is far from fool proof and a crashed CPU can leave the blanking high and solenoids and lamps locked on. When the lamp column drivers lock on the 27R resistors on the driver board will get smoking hot to the point they burn open circuit or even desolder themselves off the board. The run hot normally, but if they literally smoking hot, it probable have a locked on column driver.
The blown solenoid fuse is typical too. Blanking fails to detect a locked up CPU, solenoids lock on, sol fuse blows, lamp drivers lock on, 27 ohm resistors burn. Fix the locked up CPU before diving down lamp column issues.
#8 3 years ago
Quoted from barakandl:
Ok, wowza, I'm pretty decent, but what's the locked up CPU? Blanking?
I just got it fired up enough that I was able do a solenoid test, it hit every coil, sound, all lamps on.
I bought enought TIP125's to do the 8 in the run an replace the hot ass resistors with 10K ones also.
I think my 40 pin connector is newer, it looks newer. This is my first SYS 6 so be easy on me with slang and acronyms on them please
#9 3 years ago
Here’s what I’ve got going on
#10 3 years ago
Here’s my current issue.
Game seems to play great, down to a display issue.
#11 3 years ago
I’ve read the wiki about displays. Damn that’s hard to understand, I read it and my brain hardly comprehends it
#12 3 years ago
Kind of looks like a segment decoder issue to me. left side of the display schematic or BCD connector on MPU. It goes PIA -> encoded data out J5 -> into Master Display -> 4543 decode segments. Make sure MPU J5 does not have any broken solder joints.
OR maybe is digits getting enabled at the wrong time showing junk data?
#13 3 years ago
Thx, I'll take it out and give it an inspection. At least I have a starting point. Maybe an old weakened solder point. If I have to reheat and reflow i'll tackle that job!
#14 3 years ago
WOW, ordered transistors and resistors from digikey
Already arrived, can do to that board preventative maintenance .
DB92B123-889F-4D1E-94C6-1B788257A1DB (resized).jpegDB92B123-889F-4D1E-94C6-1B788257A1DB (resized).jpeg
$ 11.00
$ 170.00
Displays
Digipinball Shop
Tools
Pincoder Store
$ 130.00
KAHR.US Circuits
$ 9.95
$ 27.95
This page was printed from https://pinside.com/pinball/forum/topic/troubeshooting-a-scorpion-williams-sys-6 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
