Hi guys,
I have a Tron pro machine and it has been working solidly for years. Recently though the upper left flipper locked on and blew the fuse.
I replaced the transistor with an IRL540N and changed the diode that sits next to it on the board.
When I turned it back on the flipper stayed down, i flipped it once and no issue, then i flipped it again and it locked on and blew the fuse again.
I checked the resistance across the coil (disconnected) and got a reading of 4 ohms, as far as i understand it that means it is okay.
So i have changed the transistor and diode on the driver board again (Q12 and D12) hoping that it was a bad transistor i had put in. When i turned it back on the exact same thing happened. Flips for one press of the button fine, then when you press the button again it locks on.
What am i missing? its driving me spare because it takes me ages to change transistors.
Any help would be great.
Thanks,
Eric
