(Topic ID: 58705)
TRON tech: Recognizer flashers under PF
By snaroff
10 years ago
  • 13 posts
  • 9 Pinsiders participating
  • Latest reply 10 years ago by tktlwyr
#1 10 years ago
There are 4 red recognizer flashers under the PF that keep on going out on me. Anyone else experience this? It's happened twice since I purchased the pin a couple months ago. The LED's I installed 4 weeks ago were new. I need to lift the PF and see if they just need to be reseated, however even if they are loose it's still a pain to have them go out after only 50 plays or so.
#2 10 years ago
I'd check voltage, and then be sure the LEDs you put in there can handle it.
#3 10 years ago
You are not talking about the 4 sockets mounted by the spinning disc? Those are just 555 wedges.
#4 10 years ago
If they are PBL led's, sometimes the wire leads on the 555's are not exactly where they should be relative to how a 555 bulb is; I have had to fiddle with the wire leads coming out of them sometimes to get them to make proper contact; and even then have to adjust them occasionally if they get vibrated off the contacts of the wedge sockets.
#5 10 years ago
Hmm...Stern manual says it should take a #161 bulb (14-Volt, .19 amp). I never "stock" #161 bulbs. I think I put #906's in there...shouldn't they work?
#6 10 years ago
I replaced mine with flex 555's, and noticed that a couple had been "chopped" off with burnt tips - I guessed that they were hit with the nuts of the underside disc spinning. I know that they are called flashers, but still thought that they were originally just 555's with bulb covers, not flashers.
#7 10 years ago
555's aren't the correct bulb. Sockets are spec'd for #161 (hard to find #161 LED's on the pinball websites). Found these on eBay...inexpensive and work great! Screen_Shot_2013-08-10_at_7.34.28_AM.pngScreen_Shot_2013-08-10_at_7.34.28_AM.png
#8 10 years ago
I was just looking into this. CoinTaker recommended flex's. I might go this route if it works.
Although I havent seen a 161 to buy yet.
#9 10 years ago
Quoted from huo:
I installed the 161 bulbs above and they work great. flex's would work if they are spec'd for 12 Volt (161). If not, they will burn out fairly quickly.
#10 10 years ago
I've been using these 9 LED ones from Amazon with no problems. Plus at 1.70 a bulb you can't beat the price.
http://www.amazon.com/gp/product/B0081448E6/ref=oh_details_o03_s00_i00
#11 10 years ago
I have used the following two LEDs from CT:
http://shop.cointaker.com/product.sc?productId=434&categoryId=8
http://shop.cointaker.com/product.sc?productId=1591&categoryId=8
For those four sockets, I prefer the SUPER 906 RED over the FLAT 8 RED FLEX 906. I have also read others having the LEDs ripped off due to the FLEX head getting caught in the motor.
#12 10 years ago
Quoted from asnatlas:
Are you sure 906's are compatible with 161's?
I didn't think so, but I'm no expert...
Curious
#13 10 years ago
Quoted from snaroff:
Curious
Steve,
Technically they're rated different but they do work. I have them under the disk in my Tron and previously had 906s behind the lightning bolts in AC/DC (now replaced with PinBits lightning bolts), both without issue.
YouBentMyWookie
$ 9.95
Mitchell Lighting
8,500 (OBO)
Venice, FL
$ 109.95
Hookedonpinball.com
Filament Printing
Trade
YouBentMyWookie
$ 40.00
Disk war combatant Pre-order!
RamMods
$ 649.95
Pin Stadium Pinball Mods
Professor Pinball
Lighting - Backbox
$ 8.00
Playfield - Plastics
Minty's Mods
$ 99.99
$ 6.00
Minty's Mods
$ 350.00
Professor Pinball
$ 14.95
Mitchell Lighting
$ 99.00
PinballReplacementParts
$ 200.00
Professor Pinball
10,250 (OBO)
Willington, DE
PFX Pinball Mods
$ 11.95
Huntington Beach, CA
$ 135.00
Dijohn
$ 79.00
Lighting - Under Cabinet
Arcade Upkeep
$ 24.95
This page was printed from https://pinside.com/pinball/forum/topic/tron-tech-recognizer-flashers-under-pf and we tried optimising it for printing. Some page elements may have been deliberately hidden.
