having phantom disc hits registering on my pro. here's the facts;
1 replaced both optos and amplifier board for disc
2 optos register in switch test with ball
3 optos don't register in switch test when 'banging' on playfield
4 spinning disc works under solenoid test
5 during gameplay with spinning disc power disconnected, not getting phantom hits.
6 with disc powered up and running during gameplay getting phantom disc hits register.
7 pulled out disc and inspected, everything is tight and good
8 disc looks to be flush on top of playfield
9 disc pad is on well and flush
10 disc doesn't spin offset
edit..optos are mounted correctly and tight. no way to adjust them.
i'm thinking about adding 4 small washers under the opto mount brackets imbetween the opto mounts and the pf to elevate them 1 cm to hopefully resolve having this issue. was wondering if anyone else has had this problem/or had ideas? if not, i'll let you know what happens with the spacers added.
thanks
