BAA doesn't sell them. Any idea who does? TIA
I don't even shoot for the Flynn skill shot anymore. I now full plug with left flipper held and hit the ramp skill shot. The Cliffy does protect the hole so I am keeping it on but mine gets stuck all the time. I even have time during multiball modes where a ball hangs.
Even after all that, I still like it and will not take it off.
I just put a mantis in mine. Doesn't interfere with gameplay but doesn't protect the beveled lip. Not sure what the lip will look like after hundreds of more plays.
I have a scoop area protector Cliffy on both our Xmen and Tron and they are awesome. I've had ball hangups from both of the scoops, but it's something simple to fix. Below is a picture of our Tron scoop protector, it went on before the 1st game was played and we've now got 1,200 games on the machine. After a few hundred plays I started to get the ball hangups. The problem is the back lip bending up a bit (where the notch is) and the ball hits it. To fix this all you need to do is take the Cliffy out, get a pair of pliers and a cloth. All you need to do is bend that notch part back down so that it's level with the playfield again. You don't want to put the pliers right on the Cliffy, so use the cloth in between the pliers and the Cliffy (this way you won't scratch it). I've played about 600 games since I last did this and I'm just starting to get the hangups again. It only takes about 10 minutes to take it out, fix and reinstall.
Sure it would be nice if the Cliffy was indestructible and didn't bend at all, but my scoop area still looks like brand new and I'm more than happy to fix it every once in a while if I have to. Once you bend it down it's perfect again and the balls roll right into the scoop.
That cliffy is pointless. The most wear will happen where the cliffy is cut as that is where the ball rolls in most of the time.
I disagree. The slow roll through the cutout is not going to do much damage, but a full speed shot from a flipper hitting the inner edge of the wood will.
I had balls hang on mine too, but after cutting a small bit of extra metal from the cutout and bending the protector back into shape, no more problems.
Quoted from pinlawyer:But WHO sells them? Cant buy from Cliffy's site.
You just email Cliffy.
Yer shittin' me, right Greg? Alzheimer's settin' in?
Quoted from herg:but after cutting a small bit of extra metal from the cutout and bending the protector back into shape, no more problems.
And thats what I'm doing on the newest version, ie, cut back a tad more on the upper part of the notch (thanks to suggestions from a few die hard Tronners
I love our full-cover Cliffy for the scoop. It's taken a real beating there, and holding up strong.
Hangups are so rare , it's not even worth mentioning.
I have a cliffy in my Tron, no hang ups at all so far. I prefer the Cliffy style scoop protectors because I like the added coverage. Definitely put either a Cliffy or a Mantis in as soon as possible though. I got my Tron used, and the scoop hole had already taken quite a beating.
Quoted from Cliffy:Yer shittin' me, right Greg? Alzheimer's settin' in?
LOL. Priceless. Just email the Cliffster and he'll get you squared away.
Quoted from rai:I'm trying to understand on a new game with no wear, what's recommended for the slot of XM and Tron ? Cliffy or Mantis?
I actually use BOTH in my Tron LE and it works like a champ
It depends on who you ask. I prefer Cliffy's protectors myself, because the edge of the clearcoat is still somewhat exposed with a Mantis protector, especially on scoops where the edge is beveled.
I had only mantis installed for a good 6 months before I started to notice a tiny spot developing that Mantis did not cover so I added the Cliffster as well.
Had to double-bag it. I don't know where that hoe has been :-p
Quoted from fattrain:I had only mantis installed for a good 6 months before I started to notice a tiny spot developing that Mantis did not cover so I added the Cliffster as well.
I had the Cliffy version 2 and was getting hangups. I changed to Mantis and have a teeny spot where the clear on the bevel is kind of more white than clear. I'm gonna order a Cliffy version 3 and double up like you and see how that holds up.
Quoted from rockinganker:I took mine off, rebent it and now it's working 100%. Thanks for the tip.
Not a problem at all, good to hear it's fixed! I fixed mine this morning and thought I might as well put in a couple of pictures on a separate thread in case anyone else was searching for the topic at a future date:
This page was printed from https://pinside.com/pinball/forum/topic/tron-pro-who-sells-protectors-hole-isnt-protected-at-all and we tried optimising it for printing. Some page elements may have been deliberately hidden.
