Quoted from DrMark12PA:No all of the bulbs (LEDs) work perfectly.... but no doubt about it, I only had 4 lit the rest weren't even blinking..
I gave you the benefit of the doubt and ran some tests on my Tron. I tried to duplicate your result a bunch of different ways, but couldn't. The one thing I do want to know is what version you are running, because all my testing was with 1.74.
I tested running all the multiballs, then dumping into the scoop.
I tested having everything flashing except Multiballs completed, then starting SOS, dumping out of it, and then requalifying it with just the multiballs, but it wouldn't start without the other modes.
I tested having everything at the scoop qualified (Clu, Quorra, LC), and everything else flashing or complete, but it just started the modes as expected.
And again I tried second time in after dumping out of them.
The only reason I was trying them all was to see if there was a faster way to get to SOS and cheat a bit, but I have come to the conclusion that you must have missed something. Have you thought about pulling the glass and attempting to duplicate it? For now I am going to go with the conclusion that you didn't see them flashing, and they went out as soon as you entered the scoop.
