Hi guys,
Inaugural post here, but long time reader
I'm posting this because I'm at my wits end with an issue on my Tron Legacy Pro machine. It will never reliably start up. The GI comes on, but no DMD or actual game-board stuff. Now the strange thing is that very rarely I can turn the machine off and on dozens of times and it'll fire up, but more often than not I'll need to jiggle with every connector in the back-box. Sometimes I touch one cable and it fires right up. Other times it won't matter how much I play with that cable, it won't fire up till I jiggle others around. I've tried to determine every combination to find a weak point or something that's responsible, but it seems to be totally random as to what makes it finally fire up.
I've replaced all fuses with the correct slow-blo ratings as per the manual, and checked all connections inside the machine. I haven't yet pulled every connector off the boards and re-seated them as some are glued and they all have difficult clips to remove -- I'm worried I'll do more damage than good doing that. It's running the latest 1.74 code.
I should note that cabinet is loaded with just about every single mod imaginable. I'm about to install the Eli ramp light kit which I think will truly make it decked out with everything there is (short of the EL side-cabinet trimming).
If anyone has any ideas as to what might be happening I would really appreciate hearing from you.
