(Topic ID: 218659)
Tron LE flippers stop working
By moonwk
5 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 5 years ago by arkuz
#1 5 years ago
Hi all tron lovers. I have been having a problem. I recently got a tron LE but I noticed that while I’m in the game the flippers stop working, the playfield goes dark, and the game ends. There is no tilt message. It particularly happens when I’m in the disc mode. Does anyone have any suggestions? Thanks
1 month later
#2 5 years ago
I have noticed this too, but only since I installed easy mode. Have you done that too? Been playing for a couple years without trouble in factory default mode, but have never been good enough to make it through all the modes and through all of Sea of Simulation, so I finally caved and tweaked the difficulty level down. And that's when I experienced the weird flipper dying phenomenon. Just like you describe, as if a tilt occurred but without reason to. Game resumes fine after losing the ball.
I might have to sell the game soon and so I have less than my lifetime to try and beat it, was hoping to achieve that through easy mode. I will eventually restore factory defaults if this bug persists (and stymies my efforts to make it through to the end of the game -- almost like the coders are laughing at us!).
#3 5 years ago
Made it Portal finally, yay, and have had no recurrence of this flipper issue since my previous comment. Will be going back to factory defaults now anyway...
#4 5 years ago
Quoted from moonwk:
Game ends regardless of ball you're on, or game ends like that when you're playing ball 3?
3 weeks later
#5 5 years ago
The problem lingered for me, but was just balls ending unexpectedly. I figured it had to be a trough issue -- switches or optos, and indeed saw on Marco Specialties their notes about Stern trough optos failing with symptoms like this. I ordered and installed a dual opto replacement kit and all appears to be well now. I recommend the OP try the same.
#6 5 years ago
Quoted from arkuz:
You likely could have fixed your issues by bending out the two prong connector on one side of the trough opto. That one seems to cause most of these issues because the connector becomes loose and intermittent. Of course it could have been a bad/intermittent opto, but most of these are the connector becoming loose over time. Simply bending the two prongs on the connector out a bit so it tightens the connector bond is usually enough.
#7 5 years ago
Good to know. I did suspect loose connectors, and did fiddle with them a bit, but perhaps could have tried harder to solidify the connections. Might still give that another try to know if I have spare working optos, thanks.
$ 18.00
Volcano Pinball
$ 24.95
$ 40.00
Disk war combatant Pre-order!
RamMods
YouBentMyWookie
$ 109.95
Hookedonpinball.com
$ 11.95
$ 6.00
Playfield - Plastics
Minty's Mods
Lighting - Backbox
$ 50.00
Duke Pinball
$ 14.95
Mitchell Lighting
Professor Pinball
$ 135.00
Dijohn
$ 8.00
Minty's Mods
YouBentMyWookie
Filament Printing
$ 9.95
Mitchell Lighting
$ 99.99
$ 99.00
PinballReplacementParts
PFX Pinball Mods
This page was printed from https://pinside.com/pinball/forum/topic/tron-le-flippers-stop-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
