These are some photos I took during a build that I was too tired to post last night. Just want to quickly show how the layers work.
The left, center, and right parts are separate pieces, with solid black acrylic light spacers between them. If I don't completely optically isolate each part the light will find away even around corners to faintly light up sections when I want them to be dark.
After the first layer is set there's a masking layer over it that provides the same isolation, but this time in the perpendicular plane.
The next layer is built the same way, but it's mirrored, so this time the etching is facing down, instead of up. This way the two sides that glow are almost touching, only separated by the black chip board mask, which is about 1mm thick. This gives a nice subtle 3D parallax feel to things if you move your head.
Then finally I start building up the other layers that provide enough depth to sink the silicone ring in the middle, and the FLYNN'S sign. I forgot to document how the sign works, but it's a similar principle. The N is optically isolated so I can flicker it without the rest of the sign bleeding into it.
