And it lives! I was able to get it up and flipping!
Surprisingly enough, there weren't many lamp issues. I did have to replace the 2 lamps sockets on the coin door to get those, and the bright mods flipper buttons working, but that was it. I need to test the voltage at the pop bumper lights, because those seem dim with the brite mods pop bumper discs in there. I might still play with the colors under the plastics. I'm also thinking about adding a white strip in the trough to help light up the middle of the playfield a little.
I spent some time with colored lights behind the back glass to help hide any imperfections and obvious signs of touch up. I think it is looking pretty good now.
I was really happy with how the displays look. I think mixing green blue and white displays looks really good over the old amber plasmas.
There are still some issues to clean up:
- I need to work on the drop target. The relays aren’t dropping so I need to troubleshoot why. My best guess is that they are daisy chained if I remember correctly. If that is how in fact they are wired, it would make sense that none of them would work with a bad common hot leg.
-The aprons on the pop bumpers need some attention. They get stuck from time to time so the spoons need adjustment.
-The upper switch next to the kick out hole needs some adjustment. I forgot all about it when I was going through switches earlier.
-I need to track down why I have no sound in regular operation (The sound is AWESOME when running the BSOS Trident 2020 code)
2C98843F-69C0-4E8A-983A-FA2BAD561DA5 (resized).jpeg52038275-14EB-4CE3-AC82-14B67EF39E60 (resized).jpeg8AF79540-65B7-48DD-9F21-E861A1B50DD3 (resized).jpegCFFA7D7A-81DA-444B-9D47-6332C1B4DAE2 (resized).jpeg
