Is Tri-Zone supposed to have background sound? I believe it came after Flash, so I would think it should......
The rest of the sounds in the game are working, as are the cheesy chimes if you flip the switch.
I've already re-flowed the connectors with new solder, cleaned up the connector pins with a little Dremel wire wheel, removed the chips in the sockets and cleaned up all the pins with a different Dremel wheel and reseated them.
I'm sure the caps need to be replaced.... so that kit is on order.
Anything else to try or is there just no background sound on this game?
Kevin
