(Topic ID: 288709)
Travel Time Pulse Unit
By BBrave
7 months ago
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 7 months ago by BBrave
#1 7 months ago
My Travel Time has a double switch on the Eject Hole. From pictures of other machines it looks like one lead from the switch went to one of the Pulse Unit terminals but there is nothing on the schematic showing this wire. What terminal does it connect to and what effect was it intended to have on the Pulse Unit?
#2 7 months ago
Hey B, I think I found the 2 switches you are referring to on the schematic. Hopefully these pics help.
B0D85A38-F50F-49D4-9744-FDD565268D1D (resized).jpegD6C9FDD0-E8D1-4B55-AD49-6124ABD1D196 (resized).jpeg
#3 7 months ago
Thanks but that is the shooter switch, the switch I'm trying to figure out is the is on the eject hole. Whoever worked on this machine destroyed the pulse unit by mixing up the wires and the wire from the eject was not connected to anything.
#4 7 months ago
Ok, can you post some pics so I know what we’re looking at? I don’t think my eject hole has a double switch, but the shooter does and one of the wires goes to the pulse unit, so that’s why I thought it might be the shooter.
#5 7 months ago
On second thought, I'm betting that even if the schematic doesn't show the eject switch in parallel with the shooter switch, it probably has the same function and same connection. Thanks
