TRANSPORTER: THE RESCUE Club, "Beam Me Up, Bally!"
By spiroagnew
1 year ago
Stats
  • 375 posts
  • 52 Pinsiders participating
  • Latest reply 1 week ago by Sliderpoint
  • Topic is favorited by 18 Pinsiders
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
There have been 96 images uploaded to this topic. (View topic image gallery).
There are 375 posts in topic. You are on page 6 of 8.
#251 88 days ago
Quoted from TecumsehPlissken:
ready to place my order as soon as they become available
+1 how and where do we order ?
#252 88 days ago
Hope someone posts here when they are available. I'll be in for one as well.
#253 88 days ago
They will be only available on PPS website. I will let you know as soon as we run the mold. Won't be long now!
#254 87 days ago
That thing is a beast! Definitely in for one of these. It'll be nice to be able to see the playfield again instead of looking through a yellow haze.
#255 87 days ago
very cool stuff!
#256 87 days ago
Will order as soon as they are available. Excited to see this come about!
#257 87 days ago
Thanks to Dozer1 for giving me a heads up on crossover ramp. I'm the only one in my crowd with a Transporter (that I know of) and I'd love to be able to upgrade the ramp. I'll be watching and ordering when available. I'd also be looking for replacement plastics as well. Thanks to Pin-Pimp for all the hard work.
#258 84 days ago
im going over now to pick up the mold test samples. will post pics and will do a test install of one
#259 84 days ago
Quoted from pin-pimp:
10
#260 84 days ago
As promised. Picked up 20 samples and will test fit. If ok then will send the first 20 or so to PPS then a small production run will follow.
#261 84 days ago
Super nice work you did there.
#262 84 days ago
Any chance fresh, new Orions could be made ... complete with labels :-)?
I can't believe all of the new stuff being made for this game!!! Many thanks to those involved!!!
#263 84 days ago
We are still digging through lists and molds. See what we can come up with in the future to get back to life
#264 84 days ago
simply put that is gorgeous ....... its so clear it looks crystal ! Dozer can you believe it ?! this day has actually arrived!!
#265 84 days ago
i have been pursuing and hunting this project down for years, squeaky wheel get the grease? more to come!
im looking for mousing around and space station tooling too.
#266 84 days ago
Pretty darn amazing to see it happen!
pin-pimp, you rule man!
Mousin' around = cheese traps
Space Station = upper PF ,
my guesses. They would be some great parts to remake.
#267 84 days ago
Excellent work @pin-pimp ! A new ramp cover is definitely in order now that this beauty is hitting production. @freeplay40 or @pin-pimp, is the clear ramp cover a project you will take on?
#268 84 days ago
Fit and function is good to go.
#269 84 days ago
looks fantastic cant wait to order
#270 84 days ago
Oh Wow!! That looks AMAZING!! Droool!!
#271 84 days ago
Hot f$%^&g damn!
#272 84 days ago
That is gorgeous. My pants are getting tight.
#273 82 days ago
Hat's off Kevin!!!!...Simply beautiful.
#274 82 days ago
looks spectacular!
looking forward to buying and supporting this!
#275 82 days ago
Pic of old and new. My original ramp is still intact but you can see how the old material had yellowed with age.
#276 82 days ago
The screws that attach the ramp are basically wood screws and they self thread into the material. Not really ideal but it works. I lubed up the screws to help them go in smoother and to prevent any stress cracking. It's a quick 5-10 minute install, you need Phillips and a small Philips for the 2 switch screws for the bowl. Slip your 2 rubber posts on metal stud on before installing them. Don't over tighten any of the screws!
#277 82 days ago
Wow, Kevin, your original looks in pretty good shape. I'm guessing that the majority look like this one!
12
#278 82 days ago
Thanks to Pinsider dozer1, I have the good examples of the other three vacuum formed pieces for Transporter. Since Kevin did such an awesome job on the injection molded ramp, I think I will make up the other three pieces to complete the plastic for this game.
#279 82 days ago
Quoted from Freeplay40:
Incredible!! ...I must be dreaming
#280 82 days ago
Not to get off the main subject too far, but another injection mold (I think) thing that many ask about is the "ball lifter" on the upper PF of Banzai Run
#281 82 days ago
Or worse.
#283 81 days ago
I know there is a lot of excitement for the new ramps being produced but I need everyone's help again.
I am trying to get two flashers working. I have confirmed via wire colour-coding that the two flashers circle below are "JET FLSHS C SIDE 05 04"
It is two flashers, one under the PF plastic to the left of the jet bumpers and one under the PF plastic to the right of the jet bumpers. The wire colour-code to both of these is black-yellow. These two flashers are part of the "special" solenoids.
I've dealt with a similar problem in the past and it was the TIP122 at fault but I decided to go through the motions anyway to help train my brain with problems like this.
First thing I did was put the game in diagnostics mode, coil test, and then to the JET FLSHS. I put my logic probe on pin 6 of U20. The signal was pulsing so I followed the signal path to Q20, and then to Q24 and finally to 1J11-5. So my initial hunch of it being Q24 didn't pan out.
On 1J11-5 the wire colour-code changes to gry-yellow. I followed this around to the Aux. Power Driver Board. Using my DMM I check for continuity from 1J11-5 to the far end. All good.
So I moved to under the playfield. I'm measured 38VDC on each flasher. So I followed the black-yellow back to the Interconnect Board in the backbox and check it for continuity. All good.
So it's not the bulbs. I checked. I even swapped both with known good bulbs.
So it's not U20.
So it's not Q20.
So it's not Q24 (the TIP122).
It's not a break in the wiring from the CPU Board to the Aux. Driver Board.
It's not a break in the wiring from the flasher to the Interconnect Board.
The flashers are getting power.
This leaves me at something possible wrong on the Interconnect Board. Unless I skipped something? Any help would be appreciated.
Thank you,
Tim
Added 80 days ago: [SOLVED]
#284 80 days ago
Quoted from EdisonArcade:
Cant wait for it to happend!
I whant one please send link when done!!!
thanks for making this happend!
#285 78 days ago
i sent the first 18 ramps to PPS on tue so watch the website for them, should be any day now
#286 78 days ago
Any idea on price?
#287 78 days ago
when will you be selling yours direct?
#288 78 days ago
all sales of the ramps will go through Rick at PPS, he owns the molds and sales, i was just contracted to do the repairs etc.
not sure on price, similar as other injection molded ramps like taxi im sure.
#289 78 days ago
Sweet! What's @pps (Rick's) Pinside handle? Hopefully he will post the price and let us know the minute these go up on the online store.
#290 77 days ago
You forgot the Orion .... no matter what, I'm buying a set of those from you when you finish them!!!
#291 76 days ago
Quoted from megadeth2600:
+1 !
#292 76 days ago
You, sir, are a saint. Finally, a @Freeplay40 project I'll be able to get in on! (All of your other projects were for games I didn't own.)
Also thanks to @dozer1 for providing good examples to work from.
#293 71 days ago
Did these ramps become available yet? I was gone for a week, I hope I didn't miss them!
#294 71 days ago
I have been checking the PPS website & forum daily & haven't seen anything yet
#295 71 days ago
I have been checking the PPS website & forum daily & haven't seen anything yet</blockquote
Me too. I assume there will be an announcement here though.
#296 71 days ago
OK, Thanks! Impatiently waiting here!!
#297 71 days ago
Same here. Following Facebook as well.
#298 70 days ago
i sent 18 ramps to PPS, they have them, only a matter of them adding the part to the website is all.
production run for more will be soon
#300 65 days ago
Apparel - Unisex
Double Danger Pinball
$ 4.00
Professor Pinball
$ 24.00
Apparel - Unisex
$ 229.99
$ 22.00
$ 150.00
Professor Pinball
$ 209.99
PinballBulbs
Apparel - Unisex
$ 66.95
$ 48.00
$ 7,999.00
Flip N Out Pinball
£ 60.00
Sillyoldelf Mods
Lighting - Under Cabinet
$ 8.95
$ 5,699.00
Pinball Mafia
$ 5,699.00
Operation Pinball
$ 99.99
$ 45.00
Apparel - Unisex
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
