(Topic ID: 252352)
Transistors in EM games
By MarkG
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 7 months ago by MarkG
#1 3 years ago
A recent comment on facebook mentioned a transistor in an EM game. I hadn't seen one before so I checked and sure enough Williams Fan-Tas-Tic uses a transistor in a delay timer:
Diodes are commonly used in rectifiers to create DC voltages from AC but I hadn't seen a transistor before in an EM game. Were they used in other games?
This circuit is a delay timer. Gottlieb used a similar circuit with a capacitor and diode in games like Flip A Card. Bally used a clever delay circuit that relied on a 455 flasher bulb to provide the delay. Did Williams use a delay circuit before this one without the transistor?
Inquiring minds want to know...
/Mark
#2 3 years ago
I think grand prix has a similar delay circuit. Later though...
#3 3 years ago
Grand Prix does have a Delay relay (upper left in the schematic below) but it uses a capacitor-diode circuit similar to the one Gottlieb used.
Interesting that Grand Prix is several years after Fan-Tas-Tic but doesn't use the transistor. I wonder if the circuit requirements were different or if they leaned away from transistors in the end?
#4 3 years ago
Hi Mark
funny - You and I did at almost the same time write about "diodes, capacitors, resistors" --- here https://www.flippermarkt.de/community/forum/threads/firecracker-von-bally-wer-erklaert-es-mir-warum-sind-kondensator-diode-und-widerstand-verbaut.212060/ in post-2 You can see "my JPG" - Gottlieb Super Soccer and Williams Grand Prix. The OP did encounter in his Bally Firecracker diode - capacitor - resistor and did ask about.
In 2017 in the german forum there was a topic about "Mystery bonus on Gottlieb 300" - I show JPGs from there.
I am not happy with the name "Delay-Relay" - I would prefer "Relay that automatically shuts-off after some time has elapsed".
The transistor in Fan-Tas-Tic is a switch --- as long in time a little bit of DC is flowing from the capacitor downwards - through the transistor - then to the left and upwards (in the JPG in post-1) --- as long in time the "switch (is transistor)" is kept open so current can flow "Coil on Delay-Relay to the left, through "switch (is transistor)" - then to the left and upwards.
Maybe (maybe ?) the Fan-Tas-Tic solution was made as they were asking an electronics engineer (state of the art) --- then they learned "we can make it less costly - without the 'transistor is a switch' ". Greetings Rolf
2 years later
#5 7 months ago
I discovered that Chicago Coin's '75 Top Ten and Gold Record use a photo cell, I think to detect when the record on the playfield spins:
$ 5.95
The Pinball Scientist
Protection
Men
Other
$ 99.00
Playfield - Plastics
Starcade Amusement
Plastics
$ 9.95
$ 7.49
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/transistors-in-em-games and we tried optimising it for printing. Some page elements may have been deliberately hidden.
