I have a Ripley's and the right slingshot coil is stuck open. I believe I traced it back to the Q18 transistor which controls that coil. I replaced the transistor but now when I turn the machine on it just blows the transistor. (twice!) Things I checked:
F7 fuse is ok (as are all the fuses)
Coil checks out at 4.1 ohms (same as left slingshot which is working)
I replaced the diode on the coil every time so it's new
I made sure I hooked up the coil and diode the same order as the left sling
Questions I have are: Is there something else upstream I should be checking?
When I put my MM on that row of transistors they all register about 860 ohms (except for Q18 which is about 775 so that's the outlier) So, I assume about 860 are normal readings. How can I tell for sure what are normal readings for all those transistors and all the other transistors on my board? (I have the manual)
Thank you for your help.
Gary
