Quoted from DrJoe:
I think those that regularly are hitting this "roadblock" need to play other games some (if you play the same table all night, every night you'll get the shots down) and/or set up their TF harder (tight tilt, open outlanes).....I play with some damned good players regularly and none of us frequent this roadblock. Yes, we've been there, and past it some...but surely not regularly.
I have always maintained if a player is hitting the roadblock "regularly", then he is skilled enough to get the associated SJP with the faction. You cannot flail and win all the other modes-it takes skill. So if one keeps getting 4 solids and no SJP over and over, then something is amiss with the player (sorry it cannot be purely the lack of mb progression).
Regular implies one can pretty much do it at will assuming no house balls/games. I'd love to see the stats of what "regular" means. To me, regular means if they play basically any TFLE set up like the one known how to play, within a game or 2 of learning how that machine reacts, it will be reached.
So I think the roadblock truth is along the lines that the roadblock happens more often than one would like, or they had a few breakout games with all modes done and were frustrated because they were so close to SP and had to play OP a zillion times.
But regularly 4 solids and no SJP? Come on, no way. The skill required to do that is not consistent with constant failure to reach the SJP regardless of mb progression.
If some reading says "yes way", ask youself how can you be so good at all the other stuff "regularly" and rarely get the SJP? Seems the answer is work on your MB technique, not blame George and Lonnie for no progression. It is doable, but yes, hard as hell and frustrating at times.
In summary, I feel it can't be both ways. Someone that good to reach the roadblock at will, has already reached SP and the days it did not happen-that's pinball. If you have been close but denied, get back in there! IT WILL HAPPEN! JOIN US!
Bottom line-I totally understand the roadblock is frustrating. Once progression is added, attitudes will probably change
