(Topic ID: 143219)
Transformers LE: high friction in Ironhide mini playfield
By nosro
8 years ago
#1 8 years ago
I just took possession of a Transformers LE. I have played a friend's Transformers LE and found it quite easy to rock the ball all the way to the top on the Ironhide mini playfield. However, on my machine the Ironhide mini playfield seems to have a lot more friction rocking side-to-side and on standard solenoid power, the ball will not move up the playfield at all. When I increase the mini playfield solenoid power, it is slightly better but definitely not as good as my friend's machine.
I have pushed the backboard rearward to make sure there is no interference between the Ironhide figure and the backboard, but that makes little difference.
Any other ideas?
#2 8 years ago
I have the same issue!
#3 8 years ago
I took apart the entire Ironhide playfield and found something interesting.
There are two coils. Each drives a plunger with a link. A spring is installed between the coil and the blue link like a system 11 flipper spring. A white plastic washer is installed between the link and the spring, apparently to improve the spring seating on the blue link. However, this tends to add friction to the link. I removed this white washer and let the spring sit directly on the blue link.
Problem solved. The playfield moves freely and power boost is not needed.
For future reference, the coil, spring, plunger and link of the miniplayfield are the same as those for the slingshot.
#4 8 years ago
Glad you found the solution. Enjoy the game!
#5 8 years ago
My Mini PF was rubbing on the backboard ... some tweaking and it rocked better.
I still have an issue with the PF switches registering hits, probably the ribbon cable needs an adjustment ... but I can't be bothered taking it all out again LOL
rd
5 years later
#6 2 years ago
Quoted from nosro:
Sorry to resurrect a very old thread but I was having the same issue on my machine, higher power wasn't doing anything the ball would just sit at the bottom and not move up the playfield at all.
But I took the lazy mans way out after reading this post. I took a pair of side cutters and some needle nosed pliers and very carefully snipped the white nylon washer and pulled it away with the pliers. Now the mini playfield moves the ball up and down, what a wonderful post. Thank you soooo much
$ 649.95
Pin Stadium Pinball Mods
Led
Other
Arcade Upkeep
Other
Displays
Retrocity
Displays
Professor Pinball
Interactive
7,600
Pottstown, PA
Other
5,900 (OBO)
Salem, OH
$ 299.95
Led
Tools
NO GOUGE PINBALL™
Tools
$ 6.00
Apron Envy
Protection
Other
Volcano Pinball
Protection
6,000
Jacksonville, FL
$ 1.25
Mitchell Lighting
Led
$ 54.99
Shooter rods
Led
Lighting - Backbox
Backbox
$ 16.50
Led
$ 39.00
Arcade Upkeep
Other
$ 64.00
Lighting - Under Cabinet
Under cabinet
$ 649.95
Led
$ 14.95
Mitchell Lighting
Led
6,450 (OBO)
Monrovia, MD
$ 54.99
Shooter rods
$ 49.99
$ 76.00
Lighting - Backbox
Arcade Upkeep
Backbox
$ 54.99
Shooter rods
$ 44.99
Pinball Shark
Shooter rods
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/transformers-le-high-friction-in-ironhide-mini-playfield and we tried optimising it for printing. Some page elements may have been deliberately hidden.
