(Topic ID: 188350)
Transformers LE ball won't leave trough
By moonwk
  • 25 posts
  • 5 Pinsiders participating
  • Latest reply 3 years ago by Breaking_Dad
#1 3 years ago
When I start the game the ball does not kick out from the trough. There are no error codes. Even when I pull the ball out and start the game the new ball won't come out. I don't know if this is related but I just installed a colordmd led. I don't know why it should. Please help me.
#2 3 years ago
Just to get some more info going...so you start a game...manually put a ball in play...when it drains does it do...ball over and go to ball two(even tho no ball gets kicked out)...?...or is it like no ball drained at all...?...hope it's an easy fix for you..............Joey
#3 3 years ago
Machine recognizes ball goes into trough and goes to next ball. The balls just don't get kicked out and the flippers don't work as well
#4 3 years ago
I'm thinking something electrical is wrong. I just can't see anything obvious.
#5 3 years ago
Check your fuses with a meter.
#6 3 years ago
Fuses are good but still the same problem. Any other suggestions?
#7 3 years ago
Go into coil test and see if those coils will fire. If they do then I would be suspicious the color dmd could be pulling down the 12 volts. Disconnect it and see what happens.
#8 3 years ago
Coils don't fire as well. I disconnected the dmd power and no improvement. I'm frustrated
#9 3 years ago
Way too early to get frustrated.
Just wanted to confirm that you checked the fuses with a meter?
Go into switch test and make sure the switches for the ball trough and flippers are working.
#10 3 years ago
Yes. Checked with meter
#11 3 years ago
Are any coils working? Something wrong with the interlock coin door switch? Maybe game thinks coin door is open and coils wont fire?
#12 3 years ago
The coils give message 50v/20v disabled. Can't be coin door because the game will start but flippers and coils just don't work
#13 3 years ago
Id open coin door and manually cycle the interlock switch a few times. If you push it all the way in with your hand do the coils work?
#14 3 years ago
I tried it and coils still doesn't fire.
#15 3 years ago
Hmmm look like any loose connections to the interlock switch? Almost has to be something with that switch making game think door is open.
Im assuming the red led lights in back box for the 50v 20v are off? Do any of the flashers work?
#16 3 years ago
Flashers not working either
#17 3 years ago
I checked all the connections. There might be one I missed. Which one and where do you think it might be?
#18 3 years ago
Ok so when i open the coin door there is a audible ding ding ding sound and i get this message on dmd.
50v 20v disabled
Close coin door
Or pull interlock switch to restore power.
And in flasher and coil test none work.
With a repeat of the message at top of screen
50v 20v disabled
Is that what u see?
#19 3 years ago
#20 3 years ago
And heres a shot of my interlock switch.
#21 3 years ago
And another with the door shut.
#22 3 years ago
Pulling out on the switch button allows the coils and flashers to work with door open.
#23 3 years ago
Omg! That was it. It must st have pulled out when I pulled the playfield up to connect the power to the colordmd. You are awesome. Thank you so much.
I want to thank everyone else for all their input.
#24 3 years ago
Yes! Love this site
#25 3 years ago
There's that easy fix I was hoping for....let me know if you ever want to jam a few games... ...............Joey
$ 99.00
Arcade Upkeep
$ 64.00
Lighting - Under Cabinet
$ 54.99
