Quoted from flashinstinct:Anyone ever have problems upgrading there TFLE? I've tried 3 sticks of different sizes ranging from 250MB to 16GB and always the same problem I get the insert USB stick message and then nothing?
No issues and it sounds like you have tried the fix I would suggest (different USB stick). May be time to call Stern to see if they have any suggestions. I'm wondering if the USB port on your game has gone bad as it sounds like it's not even recognizing that a USB has been installed. Silly question but does one of your sticks light up when it's hooked up to a computer? If so, does it light up when in the game? If not, then that would be a sign the power to the USB port is bad.
Quoted from Don44:Hi all, I just got a tfle and I have a question about the upper playfield. When I get a ball up there and the gate closed I flip the flippers and the upper playfield rocks back and forth but the ball just kinda falls to the bottom and sits on the gate and never gets up the playfield to score points. Is there something I am doing wrong or could not be working right?
Rick has you pretty much covered here already but one other thing to check is that the rubbers on the upper PF are correct. I've seen people wrap them wrong which will impact the ability of the ball to walk up the PF correctly (I'm guilty myself). I've seen where people stretch the rubber past the post it should be at (front, rear or both). Should look like the attached. Also, you can replace the star post (pointed out in orange) with a standard post. That will open the lower section up just a little which will help to get the ball started. It also has the added benefit of opening up the opening just a little bit which speeds the entrance and exit of ramps shots up a bit.
On a side note, once you get board with the mini PF, take the gate off. Makes that much more challenging (and fun) IMHO. I hated that feature until I did that and now I like it. Pretty cool that you can stack modes in to that mode as well without the gate. I played a game recently where I started Iron Hide scoring, lost the ball out of the mini PF which started my mode (don't recall which robot it was), shot the left ramp which started star scream with my next shot going into megatron for ball four. Wasn't planned as that is not an ideal stack but having a robot mode, star scream, Iron Hide and Megatron all running at the same time was pretty crazy/exciting.
