I am fixing up an early-sample Williams Indiana Jones. While removing the transformer, I noticed these two wires are clipped from a plug. Is this intentional from the factory? If not, am I safely able to fix this? I'm not an electrician but I assume I can just strip the casing and twist the wires together and shrink tube it.
What was the reason for someone to do this? The pinball machine booted up just fine before disassembling, the only issue it had was a hum noise from the DMD that would get louder the more lit up that it was.
