Hi everyone, I've got an odd problem I'm hoping someone can help with. The original problem was the Reset Motor continually ran and I assumed was just a contact adjustment on the index...so I gapping the Index Reset Motor switch. The game played but then I was chasing a problem with the roll-over specials, until I realised it was still a problem with the Reset Mechanism...so this is what it does -
When starting a new game it resets the special relays as it should however the motor continues on or freewheels (with no power) enough to lift one of the Cam lobes, creating my in play special issue. If I power the motor (tapping index switch) then brake the cam by hand to where the index switch is open, the game plays perfectly. Thought this may be a tension adjustment on the Cam Followers issue (not sure what they're called - they contact the cam with some tension) or do the motors have another way of 'braking' the cam?
Any ideas/help much appreciated, Steve
