(Topic ID: 318044)
Toy story erratic wheel spinning issue
By Loganpinball
8 months ago
  • 13 posts
  • 7 Pinsiders participating
  • Latest reply 4 months ago by karmitte
#1 8 months ago
Brand new out of the box and spinning wheel goes crazy. I went to switch tests and the 3 sensors in the wheel are registering. Calibrating the wheel via menu it spins out of control and gives “spinning to fast” error. I have no idea? I tried updated code and it does the same thing. I looked at the wheel slot sensors and paddles and they looked a little high on pathway through vanes. I lowered it just a hair and it still goes crazy. When you turn the machine on the wheel will go crazy in spurts as it boots up., Any ideas?????
#2 8 months ago
I think I got it sorted out. The plate wheel stud through the bushing only had a very thin washer under the screw. If you pushed on the screw end the plate would rise and the switches would not read when pushing upwards on the screw. When the wheel spun the force of the spinning would raise the wheel and cause it to loose the positions with the switches. I added a thicker washer and it has a smaller amount of play vertically. It tightens to the shaft, so theres no worry of it wearing out or hitting.
The screw driver is pointing out the two washers in place now and so far the wheel is fine.
#3 8 months ago
Good job. You should alert the manufacturer to this potential problem.
#4 8 months ago
I had the same problem it was just the wires in the back box came off in shipping just put them back on and all set works perfectly! It was the one on the bottom right 2nd one in from the bottom I think it was all white or gray? Good luck !!
#5 8 months ago
Quoted from Loganpinball:
Wow! The noise is even worse than POTC’s! Glad you got it sorted out! I had to fix several issues on my old POTC….you guess it, right out of the box as well!
Hope this is the only issue you have to fix on your new 12K game!
3 months later
#6 5 months ago
Hi Loganpinball ,
I have exactly the same problem.
My wheel has gone crazy and won't stop.
I can't unscrew the metal screw, and I don't dare to force it, do you have any advice? Thanks a lot.
#7 5 months ago
Quoted from karmitte:
Hi Loganpinball ,
You know that the wheel test can take over a minute to complete,it may seem like it will never stop.give the test a try and see if it finishes take a while.
#8 5 months ago
Hi Loganpinball ,
Are you turning it counter clock wise? And as others have mentioned check the connection to board in backbox. The cable could also be the issue.
#9 5 months ago
Quoted from rockrand:
My game would not pass the self test in operators test menu. Thats why my wheel was going crazy all the time. I had the playfield pulled out and on the rubber feet rests in switch test mode. First rotate the wheel so that one of the plastic vanes (hall effect switch) is centered between the sensor. Then in switch test push up on that screw that holds it to the motor. My switch would trigger every time I pushed up on that screw. There was too much freeplay and when the wheel spins the rotation causes the plate to lift up and that caused the switch not to read. I added another washer to take up the slack. If you have same problem add a washer, but there still needs to be freeplay up and down in that shaft. I hope that explains it better.
I am suprised that the screw is that tight. Small ones like that usually break when ove tightened..
Check the cable in the back box if the above is not your problem. After those 2 things you would need to call jjp. Good luck.
#10 4 months ago
Hi all and thanks,
For information and to complete my post, JJP think, it's a issue with the IO Board.
They send me a new one ... wait & see ...
Thanks all for your help.
#11 4 months ago
Problem solve.
If others have the problem, my problem was the I/O Board, JJP sent me a new I/O Board and it works now.
It's very easy to change, and JJP is very reactive.
#12 4 months ago
Problem solve.
How many hours of troubleshooting did it take until you discovered it was the I/O Board?
#13 4 months ago
Quoted from Freakyguy666:
JJP was very reactive, I sent a video of the problem, and 2 hours after, they said it's the IO Board.
I have rarely seen such a responsive support.
$ 14.95
Toys/Add-ons
$ 16.95
Protection
$ 11,999.99
Pinball Pro
Trade
Machine - For Trade
Topeka, KS
Men
$ 350.00
Eville Pinball
Armor and blades
$ 15,000.00
Classic Game Rooms
This page was printed from https://pinside.com/pinball/forum/topic/toy-story-wheel-out-of-control and we tried optimising it for printing. Some page elements may have been deliberately hidden.
