Quoted from TreyBo69:That’s why leaf switches are better than opto. You can dial in the sensitivity to your preference. I can lightly graze the button for a tap pass or flip like normal.
This is what I'm having trouble with.
For a classic machine, the voltage goes through the flipper leafs, if you have contact, such that there is a direct correlation that impacts your flipper coil.
In the case of a Data East and later PWM type flipper circuit, the flipper button leaf is just a on/off so far as the machine is concerned. The only variable would be the duration of the switch closure. Technically this should be possible with optical as well... although perhaps the fliptronics board does not facilitate such a case.
Anyway, it's good to know it is possible on PWM. I'm thinking most of the machines I encounter support post transfer which is generally going to be a lot safer.. all-be-it, much less cool looking.
