(Topic ID: 221957)
TOTAN 2.0 soft. rewrite and add-on: Twilight Melody
By noitbe1
1 year ago
  • 442 posts
  • 47 Pinsiders participating
  • Latest reply 4 days ago by Warzard
  • Topic is favorited by 56 Pinsiders
There have been 78 images uploaded to this topic. (View topic image gallery).
There are 442 posts in this topic. You are on page 9 of 9.
#401 46 days ago
Quoted from pinballdork:
I'm in!!! Please let me know what to get. And I love the option to Be able to start with your new modes or the original.
Also, did you mention way back when. That you were thinking of making The fireball hurry up less frequent? That would be great!
Thanks. For the fireball launch: yes indeed, that's something I wanted to change at the beginning: there are way too many fireballs and it's being a bit repetitive.
So I've created new modes and increase the ramp shots.
This along with the tale selection were the 2 major flaws on the 1.4.
#402 40 days ago
After a long thinking about it, I will finally implement a real video mode (only screen play)
I know that when it's optional and well implemented it could be fun.
The sultan's palace is not a real video mode because the game interact with the screen depending on the direction of the shots.
I have to say that a some video modes I've seen are not fun so I didn't want to implement it to just to have one...
but...
I've thought of something I like lately: a shell game.
You have 3 cups and needs to find a jewel under the right cups after a lot of combinaison moves.
There a some tricks to make the eye lose the ball direction.
I'll share a video once more advance.
#403 40 days ago
Quoted from noitbe1:
but...
I'll share a video once more advance.[quoted image]
A video mode ! Sounds great. Some don’t like, some love it but if it’s fun, and this one looks like it, it adds to the game. All the greatest WPC has theirs! TOTAN deserves one as well.
#405 39 days ago
ok... a bit harder.... let's say the jewel is on the left cup to start:
#406 39 days ago
really hard version. Let's say the jewel start on the left cup still...
just focus...
#407 39 days ago
Is this all done just changing ROMS?
#408 38 days ago
I have with the P-ROC board a major constraint regarding the GI with LED (frequencywise...). There is no possibility to make any good effect with it so I need a firmware update to make it work properly and I asked Gerry (Multimorphic) if it could be done. Gerry nicely shared that it could but it takes time and resources...
If anyone is interrested by a Kit, let me know. Gerry told me that with enough people interested it could be done: It could help to push for this important update. Without it I would need to redo a lot of my lightning animations with removing all the GI effects I’ve done... because of the LED.... and it’s really unfortunate. The bulb and LED doesn’t react the same way and I cannot know what’s used inside the software (with LED no effect also...)
I have still work to be done but hope things get faster once the color will be finished.
Software is a lot of works and require a lot of testing to start. I may ask for a beta testing once I'll be ready, hopefully soon.
Thanks to all the people who PM me regarding possibility of a kit and the P-ROC GI issue, I have no insurance whatsoever this GI frequency will even be fixed/ change and I don’t plan to support different lamp shows other that what I’ve done with my own pinball so with LED or else. I will continue to share on my project no matter what. Next month I might have more info to know at least if there is a chance that the P-ROC firmware could be upgraded or not to fix it.
#409 37 days ago
thanks for sharing this and again for all your work. I really hope it will be fixed. The ligthning effects are really important indeed and it seems like you have dedicated a lot of time and effort on this for the best... cross finger.
#410 37 days ago
What is the exact problem you are having with the GI and the p-roc/pyprocgame? I know of no issue with LEDs, unless there is a new type of LED you are using? What happens?
quick update:
#411 37 days ago
Quoted from luvthatapex2:
It's not so much a bug. You can turn on and off the GI circuits like any driver. The difference between the P-ROC and the original CPU board is that our drivers circuits are not currently timed to the zero-cross circuit. I designed the firmware this way on purpose to give programmers better driver resolutions than original WPC machines. As a result, it's harder to do GI fading, as the timing of the PWM won't be synchronized to the AC voltage swing.
You could still get reasonably good GI (and matrix light) fading by making use of the aux bus logic controller for high resolution control of the GI circuits, but that's not as simple as just using a gi.enable or gi.patter command, and it still wouldn't be the exact same as the original game, though it'd probably be pretty good. In the early days, I wrote code to use the aux bus to give high resolution control of the helmet lamps in BoP2. Similar code could be used for high resolution control of the WPC GI. I'll see if I can dig up that code. I don't know for sure that I still have it, but a few community members have made use of it for BoP2 and AFM (saucer lights). Regardless, it'd be pretty easy for somebody to rewrite it using the virtual driver and aux port logic that I wrote for pyprocgame - that's how I did it.
I'm going to look into integrating the zero-cross signal into the P-ROC driver logic after TPF, but I'm not making any promises at this point. The alternate solutions should give reasonable results, and so far (in 10 years of shipping P-ROCs), this is the only project requesting the feature. That said, this project is amazing, and I love the desire for perfection.
- Gerry
https://www.multimorphic.com
#412 37 days ago
Quoted from gstellenberg:
- Gerry
Gerry, it’s an honor to have you here. What’s great with you is you have always nice things to say.
Yes, i want to use this board at its maximum to be able to create the lamp show I want and share with others. It’s difficult to describe here what is the added value but let’s put this: GI lamp show improved the experience and is a great opening for development . Yes I know it’s not on the other P-ROC WPC projects (CCC, Indy...) but, maybe, it could have been implemented as well if it was an option for them.
This option was possible however on the good old WPC boards with 6 levels of shading.
For me: gameplay, music,visual and lamp shows makes the pinball a unique experience and yes I’m attached to it.
#413 37 days ago
ok, here is a gameplay more advanced of the video mode (both flipper button pressed to select the cup)
regular mode:
hard mode: (for the hardcore...)
#414 35 days ago
this video mode is optional and could be activated with the make a wish with the ruby activated.
#415 33 days ago
You do a really good job! Thank you for your effort in this matter and I'm looking forward playing your software once!!!
Have you seen the video mode in Indiana Jones? Probably you did. Looks a bit like it and that is not a bad thing. But if you like a video mode that requires skill I would suggest that moving the cups faster is not really a skill game anymore. I'm quite good in these games myself and guess them right all the time. When the cups move to fast it's not a game anymore but it ends up being pure luck.
More skill and not to difficult to build is a 'Flappy Bird' kind of game. Where you jump with the right timing. Just to say that there is more skill involved when you make it harder (like with smaller gaps).
Anyway, great job!
#416 33 days ago
Quoted from PinPeet:
Anyway, great job!
thanks for the comment, always good to get a feedback from you.
I know that a video mode is not for everyone and I insist on the optional thing but I disagree on the fact the hard mode is impossible and it's not just luck. Yes it's based on speed and focus, I agree. I've played with wife and kids this week end and it's not 100% even on the regular mode. I've set a balanced difficulty according to it because it could be way too hard and then ... frustrating. The speed is the soul of this game, not magic. I'm not trying a to add jump trick which will be, I think , too complicated to handle (codewise) and then involve the luck for the player. I think this one is a mix with focus and speed and I'm fine with that.
This is an optional quick game which doesn't target to be something you can't live with, that was my intend for it.
If I find a way to increase the difficulty with new movments, I'll add them for sure. All of them are not shown on those videos anyway.
#417 33 days ago
Good feedback, thanks. You have to do what you think is best and looking at all other work you will be fine
It's great that you have the best testing team at home! lol
Cheers
#418 33 days ago
Cheers
don't mention it.... my 10 years old daughter beat me on it...
#419 30 days ago
Color is almost done. Let's share a little bit more: here is the wizard mode 2 (part 1 on 3...) reworked and in color (to be compared with video on post 320)
I'll share also on the other modes soon.
#420 28 days ago
others...
#421 26 days ago
Alibaba in color:
#422 23 days ago
COLOR is done! update soon
started last june... really looong process....
#423 22 days ago
Nice!!
#424 20 days ago
here is an update of things which come in my mind:
Since I started the color process last summer, I've reworked everything with for instance new animations, new sequences ... gameplay...
Also, good old matrix animations has been updated accordingly.
For the color:
color effects has been added such as "day and night" in baghdad, special effect in make a wish, color changing effects and so on...
Sometimes I've put different colors on some animations.
New tale rules:
For all the new tales, there is a time counter or a limitation to prevent it to last forever. If you fail, it will have incidence on the rest of the game but you still carry on your progress.
Here is a first draft of the rules:
cyclop : shoot one of the captive ball to hit the munsters.
Alibaba: rotating the lamp and then hit one for the stand up to progress (time limited).
Camel race: shoot one action light to progress. The action light change randomly.
Scheherazade: shoot the genie to start the book sequence and then hit left/right capture ball or left/right loop to make the genie desapear according to his positions. If both genies appears and both are hit, a special bonus will be given and a super bonus after 3 success.
Sinbad: hit the left loop to get to the bumpers. Once the munster is weak, finish him by hitting the genie
flying horse: (insipired by the "cat sequence" in Alien) One action target will pops up quickly and disapear. Hit the lamp will light the right target shortly again as a reminder. The target will also change after a while.
Flying carpet : hit the ramp (left and right will switch with diverter according to the progress)
#425 20 days ago
Scheherazade TM in color:
#426 19 days ago
flying horse TM:
#427 19 days ago
The girl looks cute, great eyes... What is happening to cause the genie to turn yellow is he getting shocked when he goes all static? Does him turning yellow mean something?
Looking and sounding great!
#428 19 days ago
Thanks. It’s a color effect: it’s a little bit like a ghost. We need to check if he is still there... Once the right switch is hit: he disappear from the screen.
#429 18 days ago
Camel Race TM:
#430 18 days ago
I have still some ideas in my mind and one of them is to create alternative animations which comes randomly. I like the idea that your game is unique and stuff comes up. It could happen if something has been unlock, won or else...
I am the lucky owner of a MM and have the « fatality » quotes with the dragon which comes up one in a while : something like it...
#431 17 days ago
forty thieves TM
#432 17 days ago
Looks great, cant wait to see a complete gameplay video.
#433 17 days ago
Quoted from pinballwil:
Thanks. The code is there. i have to say that with all the unfinished related projects out there, I really wanted to finish this one. However before starting it I had no idea it should take that much time to finish it... I understand however that with family time, jobs or else... some priority have changed for some after a while.
There is still some stuff to look at:
Since last June I’ve fixed a lot of bugs and changed things there and there. It lacks some new sounds I want to add but it required also time to create them. I will have more dedicated time for this now. Soon I want to start the real testing with stress test at the end. Check if everything is well balanced and so on...
I forgot to mention that I’ve added switch test to test if there is any issues with the pin. I need to finish to implement it.
Also, currently the coils power can be changed in the settings but I’ll probably add the possibility to adjust the magnet to avoid SDTM: create the possibility to shake more the ball once caught... On my TOTAN everything works great but is better to have this option anyway.
I’ve planed to improve all the light shows with new cool effects, I hope the firmware of the P-ROC to be updated at some point to let me do it with the GI.
So... gameplay video soon.
#434 11 days ago
Let me share some more infos regarding the RGB led display I’m using (I’ve been asked by PM). It’s using PIN2DMD assembly and firmware. This display is great.
Plug with USB, can be powered directly from the board meaning it ban be used exactly as the old DMD one.
Here is the link of the one I’m using but only available in Europe I think.
https://www.artcab.fr/dmd/368-pin2dmd-evo.html#idTab5
To use with TOTAN TM, nothing easier... Just plug the display with the USB cord to the computer and it will recognized as the main display... that’s it.
What’s great with this display is to be a real matrix kept the origin style of the original... could have been released by WMS...
#435 11 days ago
Do I need to buy a Totan now?
C’est cool, tu dois avoir du temps pour avancer..quand penses tu finir cette version 2.0?
#436 11 days ago
Quoted from colonel_caverne:
Oui il faut acheter un Totan. Le problème de ce flip était le soft. et aussi le lance bille auto.
J’ai fini un premier jet du code. Il tourne. Maintenant il faut valider que tout fonctionne bien et du pofinage.
Bizarrement, en ce moment j’ai pas mal de boulot et je dois aussi faire la classe avec mes enfants donc c’est pas si propice que ça. Et tout cas ça avance! Encore quelques mois et ça devrait être bon. La rentrée peut être.
#437 11 days ago
Oui, etre prof ocćupe pas mal de temps...ils sont fous de donner autant de devoirs!
C’est cool le boulot que tu fais, hate de voir le résultat. Bon courage camarade.
#438 11 days ago
First time to use Google translate on pinside. I love it!
#439 11 days ago
Quoted from marioparty34:
Lol! I use it every time I want to post here....Ok less and less..but i’m sure I make grammar and vocabulary mistakes
Sorry, I do not speak French again!
#440 11 days ago
Pas besoin d'être désolé! Je commentais à quel point le flipper génial rassemble des gens du monde entier. C'est un grand passe-temps!
No need to be sorry! I was commenting how awesome pinball brings people from all over the world together. It's a great hobby!
#441 11 days ago
Thanks guys. French party! Time to time it’s cool to switch but english is great to spread infos without borders for sure.
#442 4 days ago
Great work!
Any news regarding the lightshow stuff? Tks
$ 54.99
$ 54.00
$ 209.00
$ 130.00
Playfield - Plastics
Special When Lit
$ 89.99
7,500 (OBO)
Fairhope, AL
$ 50.00
