hi all
I have 2 problems with my totan and am wondering if someone can point me in the right direction.
One issue is after the 2nd ball is locked, the game recognizes this but wont release a third ball in the shooter lane. Even if i drop a ball in and let it drain, it still advises 2nd ball locked. Any ideas?
Also and this is driving me nuts. it appears half the playfield solenoids are weak. In the solenoid test, a few of them barely move when you test it. However, the same coil will pull very strong if you ground out its associated tip 102 transistor. Flippers work fine although the test says their is an eos problem on both.
Any help will reinstate my hope for man kind.... thanks in advance for anyones input
