Hello friends.
Here I have a problem of G.I playfield on my arabian. The 3 complete lines does not work.
The Backbox and the door light work well.
Th connectors J103 - J104 -J105 -J106 were redone before the failure.
I have the version of the drivers already corrected (without the diodes). I changed the J102 Driver-CPU interconnection cable.
The fuses and fuse holders are OK. The transformer output voltages are good. The voltages on the J103 connectors are also good.
I put new Triacs BT138-600. When I short-circuit the legs of the triacs, my lines light up well. I reset the game, remove and reset .... Still nothing.
In attrack mode my triacs do not heat up, they are cold. So I think it is not ordered.
I changed on Driver U2 74LS374 and U1 LM339. Always nothing.
If I disconnect my GI tray connector and I measure the voltages on the direct connector on the drivers I have about 7 VAC. By cons as soon as I connect the connector the voltage drops to 2.85 VAC.
Here are two nights that I am blocked above. Thanks for your help.
