The main magnet does not work when I hit the genie? However, after I lock two balls and hit the genie, the main magnet works, grabs the ball and multiball starts. Any idea why the magnet doesn’t work, except when multiball is starting?? Thank you.
Quoted from Jimmyhonda:The main magnet does not work when I hit the genie? However, after I lock two balls and hit the genie, the main magnet works, grabs the ball and multiball starts. Any idea why the magnet doesn’t work, except when multiball is starting?? Thank you.
The is a setting for Genie magnet strength in menu . I wonder if it is set to low . Check that and test with glass off maybe you will get lucky for an easy fix .
This page was printed from https://pinside.com/pinball/forum/topic/totan-magnet-issue-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
