I apologize for the newbie post. Our TOTAN that we've had for about 2.5 years has a ground short on row 4. It happened in the middle of playing a game. The game just rebooted in the middle of a game and came up with this fault.
We've figured out our previous machine issues, but I don't seen to be making progress with this one despite searching around online.
The ground fault does go away if I remove connector J212 on the CPU board or J3 of the coin door board.
I have checked the connections to the switches listed in the switch matrix for row 4 and I don't see anything touching ground. The exception being the ball through, which doesn't seem to have a white/yellow wire.
I've played with the multimeter, but I don't know that I've done anything terribly useful with it.
I guess I am hoping for a next step or two to further narrow down the issue. Am I right that a row 4 ground short means that the white/yellow wire or one of the switches it connects to is grounding somewhere? If I could at least be sure about that, it would be helpful so I can concentrate exclusively on those wires and switches.
Thanks for any help.
