(Topic ID: 309519)
TOTAN Fuse F106 blows at start up! Help
By Holtamania
1 year ago
    #1 1 year ago
    Howdy!
    Happy weekend.
    So, I've just restored my WPC-95 TOTAN (decals and all), played it and then turned it off and put it back into the corner of the room.
    Now the error check F101 and F106 error shows on the DMD. When investigating F106 was blown and I simply replaced and turned the machine back on. The Fuse blows straight away.
    Long story short... I disconnected all plugs to the power drive board and identified that the fuse only blows when the J129 connector is plugged in.. (also noting that its getting 14.3 volts to pins 4 and 7 on that connector). When Tracing back the blue and red cords to the transformer.. all looks good.. What could be wrong?
    Any ideas would be amazing!!
    Thanks in advance.
    Nick
    #2 1 year ago
    Does it blow immediately or do any solenoids from J129 fire first then it blows?
    #3 1 year ago
    Quoted from Run_dll:
    immediately Run_dll .. as soon as i flick the switch under the cab, i see a purple flash in F106 ...
    Would any solenoids fire if nothing is plugged into the board except for F106? I was wondering if it was an earth cable touching a led or something.. but considering everything is unplugged (even including the ribbon from the cpu to driver board) it doesn't make sense...?
    #4 1 year ago
    Start with diode D11-D12-D13-D14 on the powerdriver. Any of these shorted ?
    #5 1 year ago
    Quoted from zaza:
    zaza Thanks!! Looked like all 4 of those are giving a really strange reading (shorted) or no reading at all. I assume I need to replace these, what would cause these to short? Could it be linked to something else on the board?
    #6 1 year ago
    Diodes do fail over time due to aging and stress.
    Best is to lift one leg of the suspect diode and measure out of circuit.
    Quoted from Holtamania:
    It could be the capacitors C11+C12 but that is quite rare
    #7 1 year ago
    Quoted from zaza:
    Thanks mate, ill give it a go during the week.
    I also wonder if it could be from a short from a solenoid or similar? I was testing the left hand side ball save / cage before i shifted it and it did seem to be losing power. I now suspect that would have happened from a failing diode/s.
    Thanks for the info!
    #8 1 year ago
    The fuse F106 and diodes D11-14 are for lamp matrix and 12Vreg. The solenoids are different circuit.
    Maybe the 2 circuits got shorted when working on the playfield ?
    1 year later
    #9 24 days ago
    Problem solved? Have the same problem
    #10 20 days ago
    Also interested in results. I am blowing flipper coil fuse F904 on startup. I changed fliptronics boards and same fuse blew. I checked all 3 wires from coil to board. They all have continuity and none are shorted to ground. Dr Who Bally 1992.
    This page was printed from https://pinside.com/pinball/forum/topic/totan-fuse-f106-blows-at-start-up-help and we tried optimising it for printing. Some page elements may have been deliberately hidden.
