My TOTAN has been folded up for several years. I pulled it out this week and set it up again. Everything’s fine except the flippers don’t work at all.
Well, it’s not just the flippers. The left diverter doesn’t work either. Neither does the loop post diverter. Didn’t test the vanish magnet, but it seems everything connected to J120 is having issues. J120 looks fine.
The flipper switches test fine in switch test.
The coils for the flippers and the diverters all show roughly 70 volts. If I ground the middle tab of the flipper coils they fire.
Checked fuses. F104 was blown. I replaced it and that didn’t fix anything. The new fuse did not blow. All other fuses tested fine.
What should I check next?
