(Topic ID: 97143)
TOTAN club! (fans welcome)
By mof
9 years ago
  • 2,683 posts
  • 313 Pinsiders participating
  • Latest reply 4 days ago by Zitt
  • Topic is favorited by 166 Pinsiders
There are 2,683 posts in this topic. You are on page 38 of 54.
#1851 3 years ago
Quoted from pacman11:
Alright recently picked up a TOTAN and tearing it down for a good deep cleaning. What is this part I am missing? I just removed a post in this position but from looking at others it seems to be a newton ball. Correct?[quoted image]
Yes, it should be a newton ball. PBL has the replacements (chrome) for about $8 each. You should probably check the other newton ball as well as the ball usually strips the threads and is just held in place by the plastic and metal parts around it. That makes the strike way different. I recommend you replace them both, since you have it torn down anyway. (You can find the GOLD versions too, but about three times the price.
#1852 3 years ago
Quoted from Methos:
Thanks. I'll try and wait on ebay for a bit. Does Pinball Center ship to the US?
They don’t, unless something changed. If you can connect with a Pinsider in Canada, or in Germany, maybe they can help you out. That’s what I’ve done when only Pinball Center had the part I needed.
#1853 3 years ago
What am I missing here? Just a plastic post?
9FE059A8-EAAD-447A-831C-FA07FB585DB2 (resized).jpeg9FE059A8-EAAD-447A-831C-FA07FB585DB2 (resized).jpeg
#1854 3 years ago
Yes! Right next to the genies arm in this pic
#1855 3 years ago
This is the plastic it attaches to. On the broken edge of this plastic
#1856 3 years ago
Okay I just added a post in..
58A81F97-C957-4877-8815-669F3EF75F5C (resized).jpeg58A81F97-C957-4877-8815-669F3EF75F5C (resized).jpeg
#1857 3 years ago
That should do it.
#1858 3 years ago
Anyone have this plastic that’s not cracked up..
E8A724CF-5732-4295-8620-730C38C69BD2 (resized).jpegE8A724CF-5732-4295-8620-730C38C69BD2 (resized).jpeg
#1859 3 years ago
It’s coming along.
B4279C75-87DA-4B74-8FF3-E3AD800FD169 (resized).jpegB4279C75-87DA-4B74-8FF3-E3AD800FD169 (resized).jpeg
#1861 3 years ago
Quoted from Methos:
Missing the plastic that attaches to the top of the skill shot tray (3 switches). Does anyone have a spare I can purchase?
Thanks.
ebay.com link: Williams Tales Of The Arabian Nights Pinball Cobra Plastic New
$15.50
#1862 3 years ago
Quoted from Markharris2000:
ebay.com link » Tales Of The Arabian Nights Pinball Harem Plastic New Free Shipping
$23
Nice! Didn’t realize someone sold one plastic thought I would have to buy a whole set. Thanks!
Just ordered it..
#1863 3 years ago
Just ordered it..
Remember you need a red half dome with two tabs, and the rivets to replace it in the new plastic. That half dome is rivetted to the old harem plastic and not very easy to remove. You install the half dome upside-down using two 1/8" tubular rivets and two matching washers. (You'll need the HT174 type rivet setter to do this). Alternatively, you could try some short 4-40 screws, washers and locknuts but that is not nearly as authentic.
#1864 3 years ago
Yeah I’ve used screws in the past to reattach the plastics. Thanks for the heads up on that though.
#1865 3 years ago
I drilled through the center of the back of the original rivet just deep enough to pop it loose. Then re-assembled it on the new plastic with a dab of superglue. Works like a charm and is original to the look. Have done this on two TZ in the past as well.
#1866 3 years ago
Aright putting this top ramp back on after waiting a week to get parts. Is the left ramp suppose to be lower then the right loop? See picture I am pointing at it.. Thanks!
47AB844E-C246-4659-B9E6-53E8F62A9CE0 (resized).jpeg47AB844E-C246-4659-B9E6-53E8F62A9CE0 (resized).jpeg
#1867 3 years ago
Roll the ball down it and see if it works
#1868 3 years ago
I think I’ve got it.. ‍♂️
3D2270B5-4267-4380-936D-762CC027E9C2 (resized).jpeg3D2270B5-4267-4380-936D-762CC027E9C2 (resized).jpeg
#1869 3 years ago
You got it!
8CDA28FD-35C5-4519-8F02-42D9E60857F7 (resized).jpeg8CDA28FD-35C5-4519-8F02-42D9E60857F7 (resized).jpeg
#1870 3 years ago
It’s coming along quite nicely!
#1871 3 years ago
Quoted from Green-Machine:
Thanks man! Just waiting for my Genie to get custom painted now and I am done.
#1872 3 years ago
Does anyone have a custom Genie that they painted they could share with me to give me some ideas. Thanks!
#1873 3 years ago
Here is mine that I painted
958E3894-111B-4A33-BF2F-97F1331BAD45 (resized).jpeg958E3894-111B-4A33-BF2F-97F1331BAD45 (resized).jpeg
#1874 3 years ago
D9A3725E-9451-422D-9E96-7C6C7585A9FE (resized).jpegD9A3725E-9451-422D-9E96-7C6C7585A9FE (resized).jpeg
#1875 3 years ago
Those both look nice! I like the clear coat that's on them, really gives it a shine.
#1876 3 years ago
I used automotive adhesion spray, then 3 different auto blue tones, including a metallic, then two coats of clearcoats. I hand painted the black and gold details. Took me 45 minutes in total, but had to let it dry a few times in between steps.
#1877 3 years ago
Yeah looks good man. I have someone painting for me and I’ve got some spray Max clearcoat I’ll probably put on it..
#1878 3 years ago
Okay just got my Genie back that’s been painted and I think it looks great!
6615CFED-FE74-433D-91EB-72FAA3FAE323 (resized).jpeg6615CFED-FE74-433D-91EB-72FAA3FAE323 (resized).jpegB9B49E0C-34DE-4916-9360-45D1B05DEA00 (resized).jpegB9B49E0C-34DE-4916-9360-45D1B05DEA00 (resized).jpeg
#1879 3 years ago
Where does this piece go?
#1880 3 years ago
Next to the fireball magnet. It helps lift the ball into the hole
#1881 3 years ago
It was a factory add-on early in production. Good thing you have it and quite easy to install. I am attaching a picture
ADDF5DF0-9552-4FDA-8500-6BD060C40AB2 (resized).jpegADDF5DF0-9552-4FDA-8500-6BD060C40AB2 (resized).jpeg
#1882 3 years ago
Is that modern day stern glass on your TOTAN
#1883 3 years ago
It is! My machine glass had 30 years of scratches on it. Found someone locally that swapped a few of their new machine's glass to HD glass, so gave me a sheet a few months ago. Makes a BIG difference!!!!!
#1884 3 years ago
Yes, I ordered new glass as soon as I bought mine...like yours it needed replaced
#1885 3 years ago
Thanks guys! Added a spot light to light up my Genie..
F268A6F8-3C6C-4F1E-9434-C491A229F79C (resized).jpegF268A6F8-3C6C-4F1E-9434-C491A229F79C (resized).jpeg
#1886 3 years ago
I dream of genie.
62E1F3AA-5588-4E38-A009-247ADFD9F484 (resized).jpeg62E1F3AA-5588-4E38-A009-247ADFD9F484 (resized).jpeg234EBDF8-A49B-45A6-B9D5-C54A3FE27007 (resized).jpeg234EBDF8-A49B-45A6-B9D5-C54A3FE27007 (resized).jpeg
#1887 3 years ago
On the left ramp shot when the ball hits that loop I've had it get stuck just after the switch and before the magnet. Is that a pretty common area for the ball to hang up at? It got stuck because the ball didn't have enough energy to make it up that magnet ramp area and rolled back down to the switch and the switch kept it from leaving the ramp.
A4781D19-C507-4998-8971-2A772FF4BB6F (resized).jpegA4781D19-C507-4998-8971-2A772FF4BB6F (resized).jpeg
#1888 3 years ago
On the left ramp shot when the ball hits that loop I've had it get stuck just after the switch and before the magnet. Is that a pretty common area for the ball to hang up at? It got stuck because the ball didn't have enough energy to make it up that magnet ramp area and rolled back down to the switch and the switch kept it from leaving the ramp.[quoted image]
That's a danger of a gentle ramp shot. It's one of the 8 places where balls regularly get stuck on my machine.
#1889 3 years ago
Quoted from TopMoose:
There's got to a fix to that, maybe I could relocate the switch on top or side like some games.
#1890 3 years ago
I can see what you are saying, but I got to say I have had it for 15 years and NEVER had it get stuck there... Perhaps the ramp spacers are too tall? Were they replaced at some point?
#1891 3 years ago
Ramp spacers? What are you talking about? I played it last night and got it stuck twice within an hour.
#1892 3 years ago
I think he’s trying to help you. Ramp spacers are the little plastic sleeves that go over the screws that hold your ramp in place if they’re not correctly put into order or size your ramps downhill grade could change causing your ball to get stuck.
#1893 3 years ago
I think he’s trying to help you. Ramp spacers are the little plastic sleeves that go over the screws that hold your ramp in place if they’re not correctly put into order or size your ramps downhill grade could change causing your ball to get stuck. He doesn’t see your game so of course it’s a theory so that’s why He asked I’m assuming
My ball has never gotten stuck there either
#1894 3 years ago
Yes, I know he's trying to help.. I just didn't know what a ramp spacer was but I think I know what you are talking about. Thanks!
#1895 3 years ago
Quoted from webdiddy:
I dream of genie.
[quoted image][quoted image]
Great idea for a pinsound version....
“Oh Master!”
Theme song
“Do-onig” sound effect
And of course the canned laugh track
#1896 3 years ago
Over the years, the spacers may have been changed depending on who worked on it and what they had available. What I am suggesting is the ramps may not be at the right angle causing the ball to get stuck. The slope of the ramp should be downward consistently, but over the years changes may have accidentally been made. Spacers are usually plastic, but there are aluminum and steel ones as well. Refer to page 2-42 for the location of the mounting tabs in the upper left of the play field. I suspect one or more are a bit too tall making the ramp sit too high.
#1897 3 years ago
Okay that makes sense, I’ll check, but the ball got stuck on the switch when it went backwards on the ramp. Maybe something is off, but I don’t believe so. The ramp seems to be at the right angle just seems like a poor design.
#1898 3 years ago
That switch is very tough to work on and the left ramp may need to be removed to do so. Try this, reach up there and see if the switch lever has any resistance when pressed down. You should almost feel nothing as it depresses. Any resistance could mean the lever blade has been bent, or the switch itself many be damaged and the blade is rubbing against the ramp plastic itself.
#1899 3 years ago
Here’s a thought? If you remove your glass and set the ball on your switch does the switch allow the ball to roll out of the ramp area? I’ll check my switch area too. Thanks for the help!
#1900 3 years ago
If you see there is physical resistance of any type and the ball can 'hang' in the ramp on the blade, it's a pretty easy to find the cause. If the ramp is at the right slope, then one possible issue is the alignment of the switch mounting bracket and the hole in the ramp or the switch itself. Sometimes that bracket is not exactly at the right angle (especially if the ramp is a reproduction) and causes the blade to rub against the acrylic itself. Sometime the microswitch is damaged and the blade wont move freely. I have even seen the microswitch screws too tight and causes the blade to be stiff. Try to get some more detail based on above thoughts and we can help you from there.
PinSound
$ 89.99
$ 225.00
Cabinet - (Alt) Translites
FlyLand Designs
$ 1,059.00
$ 44.99
Pinball Shark
$ 4.99
Playfield - Plastics
$ 399.00
$ 95.00
Pinball Mod Co.
$ 119.99
11,000 (OBO)
Seward, AK
$ 9.95
Rancho Cucamonga, CA
$ 89.99
$ 84.99
$ 36.95
$ 54.00
Van Alstyne, TX
This page was printed from https://pinside.com/pinball/forum/topic/totan-club/page/38 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
