Nice! Thanks for noticing and looking that up! I thought it was just the alignment of my plunger and sword. So now that you mentioned that I went and looked in my cabinet because the guy I bought the game from included a whole slew of new parts. I got a CPR playfield, CPR plastics, pinballbulbs.com lighting kit and some other stuff. I didn't realize one of the packages was an entire kit from pinbits with what looks like plastic protectors, that skill shot plastic with bracket and looks like another sword plastic. I haven't bothered with most of this stuff because the playfield is in decent shape (normal hole wear) and only 2 plastics were broken. Instead of opening the new plastic set I just grabbed a few pieces and partial set off ebay for cheap. I also have a set of cliffys wanting for the new playfield.
I am working on my TOM playfield right now so once I finish that I'll probably do the TOTAN one. Going to put that side plastic on tonight!
Working on two other issues. The bazaar kickout is still not consistently hitting the flipper (drain). I took it out and it looks like someone had to weld the tabs back together that hold the side to the scoop and didn't quite align it well enough, so there is a wider gap at the top, which seems to let the ball go too far left. I bent the heck out of it and it's better, but I think I might just order the part from Marco.
The other issue is some bunk wiring to the rear most loop flasher. Somehow that is being triggered on all flashers in that row. I need to trace that wiring and see what is going on, there were some weird splices made in that area of the wiring harness with the wires for that lamp and some close by. I'm guessing someone mixed something up.
Btw, what light trigger/tap does everyone use for the genie lit hand/eyes? I have it tied to the jackpot light right now and it seems like it would be much better if the eyes/hand stayed on the entire time specific modes were triggered but I don't see any easy way to do that. Is that how everyone else has it?
