Was wondering if other TOTAN owners frequently get this error for the ball 3 (aka "Top") lock switch? I see it a lot when I first power on my machine, then the switch tests fine and the error goes away for a while. I'm wondering if it's starting to go bad (hopefully not, since a new one seems hard to track down) or if there is anything I can do so I'm not pestered by this error so much? I should also mention - while in test mode the first couple of times I push down on the switch it doesn't seem to register, then the test is fine and knows whenever the switch is open or closed.
