Allright i have been working alot (no pin-time )
Just got home, had me a nice dinner with my family, and then got me whole 2 hours pinball play/work time.
Did read all you have been writting to me, THANK you guys alot, you all rockkk...
You gave me alot of ideas, so i took the labtop to my TOTAN, to read and try all the ideas you have given me...
Now i started axedentley touching the J103 kabels, and BAM the upperdeck of the back glass lit up!!! Woawwwww, what!!!
Yup, the problems was on J103, on one of the cabels, i dont know which one, that is cousing the problem. (doo you?)
Okey, i have found out:
First ice cold Carlsberg beer and pinball is a nice combination.
Secound the green cabel and the white with green stribes cabel, is power to the upperdeck lights on the backglass, when i mesaure those, it tells me 6,3V
Third the voilet and white with violet stribes cabel, is power to the lowerdeck lights on the backglass, when i mesaure those i get 0,0V. Thats why the lower lights doesent work.
Forth: When i measure Green/Violet/White with Green, i get 6,3V, but NOTHING from White with Violet stribes...
Where and what should i check/look at to findout why the white w/violet does not get power?
I have uploadet more pictures, of a little experiment, i did connect the White w/violet cabel with White w/green cabel, and the whole backglass did light up, tadaaaaaaaaaa...
Now is this dangerous in any ways? does it harm my pinball if i use it like this? will it couse more heat? will there be any problems like this?
THANK YOU AGAINNNN!!!
And special thanks to Sealclubber for all PM help!!!
