Quoted from Chosen_S:Good on you man, I wander if the repro would ever happen... there’s so much fluorescent ink to copy
Don't look like it will see the light of day. I sent mine to CPR so that the art-work could be scanned. And before they sent it back, asked if they could purchase it. Obviously I refused. Then they replied they need to own one to complete the CNC process. Whatever that means. The old one gets destroyed the process? Either way, they will never find a used one to buy.
Quoted from yellowghost:Don't look like it will see the light of day. I sent mine to CPR so that the art-work could be scanned. And before they sent it back, asked if they could purchase it. Obviously I refused. Then they replied they need to own one to complete the CNC process. Whatever that means. The old one gets destroyed the process? Either way, they will never find a used one to buy.
What did they offer you? How long ago? I know where a used one is.....
Quoted from Jo4114:What did they offer you? How long ago? I know where a used one is.....
No idea what they would've offered me. But I would've only agreed if they sent me a brand new playfield in return. Couldn't hurt to ask. Contact " stu" from CPR.
Loking good. Would be nice if the company that made those " playfield protectors" had a radical huh?
I found this on the second playfield. A wire had been pinched under a screw holding the flipper base plate, smashing the wire and removing it’s casing. I will put heat shrink tubing over the bare wire and make sure I don’t pinch it with a screw when I reinstall the flipper mechs.
B75FAAED-4C42-4E17-843C-2242D0EF5430 (resized).jpegTotally Rad
Bummer!
My radical has been down for some time, I did the conversion to install the rear left proto vertical kicker,
The game is awesome with it, but I can’t seem to find a good solution to keeping it working consistently with the updated roms (I don’t want to use prototype roms).
I recently found a relay that may work... just need to make time to work on it again
Amazing job! Mine playfield is almost in same condition like yours. I am will be happy if CPR will do repros for swap it.
Cleaned up the outside. Plastic cabinet protectors to cover up the wrinkled decals. New side rails and legs. I will do a little touch up also but this cabinet is coming out fairly decent with a smaller amount of work.
4AA10442-5BD9-41C6-842F-193D760C266F (resized).jpeg5EDE8C8A-88A2-4713-A6F9-6A54F7A5A25E (resized).jpegQuoted from trilogybeer:Jerry in not going to be happy but I was able to remove his name from the side of the cabinet.
Can you clean this with melamine to remove the dirty look? Or is it baked in?
Quoted from trilogybeer:Cleaned up the outside. Plastic cabinet protectors to cover up the wrinkled decals. New side rails and legs. I will do a little touch up also but this cabinet is coming out fairly decent with a smaller amount of work.
[quoted image][quoted image]
Where did you get that color of cabinet protectors?
Quoted from Clytor:Where did you get that color of cabinet protectors?
Pinball Life, dark blue.
https://www.pinballlife.com/pinguard-cabinet-protectors-set-of-4.html
Quoted from trilogybeer:Pinball Life, dark blue.
I looked at that and didn't read the colors. The dark blue looks kind of purple in the picture. Thanks.
Quoted from Clytor:I looked at that and didn't read the colors. The dark blue looks kind of purple in the picture. Thanks.
Yeah it’s actually a pretty good match and they hide the damage nicely. I should say that these types of cabinet protectors are not recommended for use on a cabinet with decals though as they can wrinkle the decal further out. I will keep an eye on it and see if they start to move the damage further. If they do I will either put the felt leg protectors under these or maybe a sheet of Mylar cut slightly larger than these.
For the flipper mech sitting on the nut on this game I did a fix slightly different than the first game. I used a Forstner bit to counterbore the hole for the post so the T-nut could be sunk down into the playfield.
69CE2286-58DE-48CC-8CBE-885029CEDF9F (resized).jpegCD7F3D9B-0C0A-4580-913E-BB941FF15856 (resized).jpegNo modifications needed to be done to the T-nut this way. I did find a post with threads all the way up on the mount. I did need to modify this post by cutting a quarter inch off the threads so it wouldn’t make contact with the flipper base.
405BC0B9-55F2-4DD0-A05B-439A7DB7034E (resized).jpegDA92E2BD-2465-4675-AAED-37DB5CD88812 (resized).jpegF31A0B91-DAFD-4A7F-B574-6A096359C538 (resized).jpegFinally getting some time to get back to these projects. I am waiting for new ramps for the left side and center crossover ramp, but I have started moving components to the new ramps that I do have. I riveted the lamp sockets onto this ramp. Removing the decals and prepping them to reuse is not something I am looking forward to. I was hoping to find new replacement decals but was unsuccessful.
7035E6E6-D078-4043-A277-A8791D9CE2C2 (resized).jpegCDADD7FD-8F18-4455-A11C-904E6821D497 (resized).jpegWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/totally-radicals/page/7 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
